Possible Oil Leak..?
Old May 10, 2013 | 11:42 AM
PunchedGuava's Avatar
Default Possible Oil Leak..?
I bought my car a couple months ago and changed the oil. About a month and a half after, I went to get an alignment and the guy did a basic check as well and he said I was 1 quart lower than normal.. After the first oil change, there was ALOT of sludge too. I had to clean the engine bay and all because it was pretty blackened, I couldn't even see what type of engine it was (D16Y8) because it was covered in grease/oil?
Anyways, I haven't noticed any leaks as far as when the cars parked because there's no oil under when I move it, but I have noticed the oil pan (I think) is covered in oil.. I have pictures.
Where heads connect to car, there's some sort of sludge..?
trans?
Any ideas as to what could be the cause? Should I be worried? Is it burning oil too fast or is it a leak you think?
Old May 10, 2013 | 11:47 AM
Former User's Avatar
Default Re: Possible Oil Leak..?
Clean the oil oil off the engine and then carefully watch where fresh oil reappears.
The most common oil leaks come from the distributor O-ring, VTEC solenoid, oil pan gasket, and the valve cover gasket.
Old May 10, 2013 | 11:49 AM
ReaperMan's Avatar
looks like a pcv failure.
Old May 10, 2013 | 12:16 PM
I was able to sort of clean it, but not thoroughly. Hopefully it's enough to notice a difference. I'll wait and check.
Should I replace the pcv?
Oh, and I also remember the guy who sold it to me saying he had some gasket replaced, didn't recall which one exactly though.
Old May 10, 2013 | 01:12 PM
ElectronBlue00's Avatar
I wouldn't. Not until you can locate exactly where the oil leak is coming from.
Old May 11, 2013 | 02:06 PM
Does PCV failure = more oil burnt? And the gaskets and stuff = leaks?
Old May 11, 2013 | 02:37 PM
The PCV system is for emissions only. Just make sure that the breather and PCV hoses are clear and that the PCV valve is working.
Old May 11, 2013 | 03:54 PM
ReaperMan's Avatar
the pcv vavle is not for emissions only. a bad pcv valve is what gives your engine a tube to breathe thru. a pcv if its not working right it will create pressure inside the engine causing oil leaks everywhere *the famous* looks like grease all over the engine. that is what our teacher touch us. the "BLOWBY" is what is transferred thru the pcv as well. if that blowby is big enough it will cause major oil leaks if the pcv valve is not working right. plus a new pcv is dirt cheap, it part of a tune up anyways
Old May 11, 2013 | 04:26 PM
1) Even if the PCV valve or hose were clogged, the crankcase pressure wouldn't build to high levels because the pressure can be released into the intake system via the breather hose.
2) If any significant pressure builds up in the crankcase, the rings are extremely worn and the engine has much bigger problems than an external oil leak.
Therefore, for modern engines, a bad PCV valve generally does not cause external oil leaks, the vast majority of which are the result of leaky gaskets and seals.
Old May 11, 2013 | 08:20 PM
xile6's Avatar
Simple green spary and a towel.
Clean it up and either baby powder the whole bottom of the car.
Start and wait for leak. It will turn the baby powder brown and your see where it's coming from.
But oil leaks most of the time a leak in that area is.
Oil pan gasket
Oil filter oring
Pcv black box oring
Crank seal
Cam seal
Transmission leak on a 5sp.
Old May 13, 2013 | 12:09 AM
Oil pan gasket
Oil filter oring
Pcv black box oring
Crank seal
Cam seal
Clever. I will give this a go soon, and yup it's a 5- spd. 2000 EX.
stephie1love
Aug 25, 2014 04:01 AM
PunchedGuava
28
Sep 8, 2013 11:23 AM
iGGY366
Honda Civic (2001 - 2005)
Dec 6, 2007 02:17 AM
sailor_55
Nov 4, 2007 09:14 PM
yuen
Nov 12, 2006 06:43 AM
