Just overheated, need help
Old May 10, 2013 | 05:23 AM
MugenEJ8Vtec's Avatar
Default Just overheated, need help
Hey guys my car literally just over heated I checked under the hood and the top of my radiator is gone .. Wat else could be jacked up because of that
Old May 10, 2013 | 05:40 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Just overheated, need help
What?
Old May 10, 2013 | 05:45 AM
Well not really there's just a big a** hole on thete
Old May 10, 2013 | 05:47 AM
The Grumpiest
Then don't you think you need to get a new one? If you ran overheated for a long while your whole engine could be done.
BTW, The rules state you have to list all pertinent car details so we know what car we're dealing with.
Old May 10, 2013 | 05:52 AM
As soon as I seen the smoke I cut it off .. I know I need a new radiator I'm askin what else could be wrong with it .. Sorry it's a 98 civic ex d16y8 no mods only exhaust and intake , 166k
Old May 10, 2013 | 06:11 AM
jbpnoman's Avatar
With that kind of overheating, your head gasket is gone, your head is warped, your block is probably damaged, your entire cooling system is fucked, and you should probably use this as a chance to put an entire new motor in the car. The cost for a working Y8 is going to be less than the cost of getting yours working properly again.
Old May 10, 2013 | 06:18 AM
Is there a way to see if my head gasket is blown with out taking it all apart?
Old May 10, 2013 | 06:21 AM
jbpnoman's Avatar
A conclusive and definitive way? No. A leakdown test is a formality at this point.
Old May 10, 2013 | 06:42 AM
sleepyaccord96's Avatar
lisle tool part number 75500
checks for exhaust gasses in coolant. that would tell you if it has a blown HG
Old May 10, 2013 | 01:34 PM
ElectronBlue00's Avatar
The top of your radiator is gone...... Is the Radiator cap missing?
Old May 10, 2013 | 02:48 PM
DumpdEJ6's Avatar
I like the tuna here
It could still be fine, depending on how long it was overheating and how hot it got. If you just noticed it when it was at like 3/4 and the steam was coming out, you're probably fine. If it had been overheated for a while, in the red, and THEN your radiator blew, yeah you might be f'd.
Old May 10, 2013 | 03:16 PM
SozeHuck's Avatar
I was under the impression that if you overheat a engine badly even once, cylinders will be out of round. Swap sounds like a better investment in the long run.
Old May 10, 2013 | 03:50 PM
B_Swapped93's Avatar
not the cyl's that go first(if at all) never heard of that but the HG goes first then either the head or block or in some cases both.
Old May 10, 2013 | 06:27 PM
andyz's Avatar
X2
Probably a big crack in the radiator is what leaked out all your fluid in the first place. So no surprise it blew to pieces.....
Junkyard radiator, a garden hose.....uh, maybe a hose or clamp or two here or there, fill er up with water and start it. If it runs you're on the right track. And you should be able to tell pretty quickly whether it idles like s.... Or not.
It's a good chance to test your diagnostic procedures...or perhaps your wallet opening procedures, depending on your situation...
Old May 10, 2013 | 06:32 PM
jbpnoman's Avatar
Are you really...someone please tell me he didn't...
What? If your advice is "use a garden hose and some water", every sensible member of this forum is going to agree with me in saying stop. Just stop right now.
Old May 10, 2013 | 06:38 PM
Lol @ garden hoses idea they'd have to be some pretty BIG hoses to even fit the rad and stat housings don't think they'd even hold up to the heat of the coolant. that was just dumb to suggest that
Old May 10, 2013 | 08:32 PM
I can get my hands on a b16a2 for 600 with 140k comes with dizzy, harness, alt and ecu is that a good price? Or he wants 1000 for the block+ tranny
Old May 10, 2013 | 09:34 PM
andyz's Avatar
To fill up the radiator guys.
Old May 10, 2013 | 09:35 PM
andyz's Avatar
Oops, flame. Did the part about junkyard radiator just flash by everyone eyes too quick and cause a brain flame?.
Old May 10, 2013 | 09:49 PM
andyz's Avatar
Also, uh, what makes you think this person didnt just overheat THEIR car and is now trying to dump it?
Old May 11, 2013 | 03:31 AM
I will take someone with me that knows about that stuff
Old May 11, 2013 | 09:32 AM
DumpdEJ6's Avatar
If the engine is out of the car and still all together, its hard to tell how much abuse it has been put through.
Old May 13, 2013 | 03:21 PM
So I replaced my radiator and figure I'd. Change the thermostat . Turn her on and she started right up with no probs. now when I drive it it overheats because my fan isn't coming on I changed the fuse because it was bad that's whys car over heated in the first place but now idk what to do
Old May 13, 2013 | 03:49 PM
slowDB7's Avatar
have you checked the fan switch?
Old May 13, 2013 | 04:02 PM
Not yet
