Transmission & Drivetrain Gearboxes, Differentials, Clutches
B18 with GSR or B16 Trans??
Old May 9, 2013 | 10:58 PM
tfsmith8's Avatar
Default B18 with GSR or B16 Trans??
2000 coupe with b18 and ls trans looking to get a new trans have two to pick from looking to 1/4 track the car n/a. My choices are a S4 (si trans) or a Y80/S80 (gsr trans) both USDM. Found my research everyone says b16 tranny and possible differental upgrade later because weaker diffs.. My question short distance 1/4 mile which would be better??
A friend and I both have the same setup he though has a gsr tranny and I am stuck with the slow ls tranny he beats me every time I'm hoping to pull ahead by making a better choice with which trans I buy
Thanks HT Guys!
Old May 10, 2013 | 12:48 AM
peteyparado's Avatar
Default Re: B18 with GSR or B16 Trans??
s4c b16 jdm trans has dual synchro's an LSD.
anyway b16 usdm si has a little closer ratios than usdm gsr i think both has same final drive 4.4.
Old May 10, 2013 | 03:25 AM
tfsmith8's Avatar
Yeah I don't believe this is JDM tranny it is just stamped S4. That's why I was curious what would be better to run?
Old May 10, 2013 | 04:06 AM
jdmh22eg2's Avatar
personally I like the my ITR which is basically a b16 lsd trans. it SUCKS to do any highway driving but I do not drive much if ever on highway so its ok for me. I like the fact I can cruise around town in 5th and still be at 2.3/2.5k rpms and have tq to pull in traffic if needed
Old May 10, 2013 | 09:10 AM
tfsmith8's Avatar
Ok thanks h22eg for the personal advice! So far I am leaning more towards the b16 trans from what I've read.
Old May 10, 2013 | 10:00 AM
jdmh22eg2's Avatar
np. btw I drive 11 miles one way to work on a 50mph county highway and 4 miles city (part of total 11 miles) and still average 30-33 with gsr w/itr trans
Old May 10, 2013 | 10:10 AM
parts@synchrotech's Avatar
Both the GSR and B16 have the Dual Cone Synchro on 2nd Gear only.
For 1/4 N/A I would go with the B16 transmission since the shaft gearing is shorter. They both have a 4.40 Final Drive ratio.
As mentioned above. The ITR trans is a good alternative since the USDM and 96 Spec JDM versions have the same gear ratio as the B16. 98 Spec JDM ITR will have a 4.78 Final Drive ratio and GSR 4th and 5th Gear ratio.
Old May 10, 2013 | 09:31 PM
tfsmith8's Avatar
[/QUOTE]
Thanks man for the good info really helpful! I'll remember your name I'd like to pay and get my Ls trans sent out and built with new gears.
Old May 13, 2013 | 05:37 AM
kyden's Avatar
which b18 do you have? that makes a big difference with transmission choice.
Old May 20, 2013 | 08:27 AM
tfsmith8's Avatar
I have a b18b1 with mild head build.
Old May 22, 2013 | 07:32 PM
sicc22's Avatar
Def have to say the B16. The LS doesn't have the high revs or TQ for the slightly longer geared GSR.
Old May 26, 2013 | 10:41 PM
PROJECT_DC2R's Avatar
I'd go with the B16 transmission, but you should consider getting a Type R transmission as well.
Old May 27, 2013 | 06:06 AM
GagnarTheUnruly's Avatar
I love my itr just expect to suffer above 75 mph.
99ekexsi
Mid-Atlantic (Sales)
Mar 10, 2011 02:26 PM
little2fast4u
Aug 5, 2008 09:56 PM
eg_franchise
Jul 17, 2008 08:11 AM
smokerz212
19
May 6, 2006 06:10 PM
blu2ksi
Jan 26, 2004 04:47 AM
