Why is my tach doing this? **video**
Old May 9, 2013 | 03:21 PM
crxguy406's Avatar
Default Why is my tach doing this? **video**
d15b2 all stock. brand new dizzy.
I recently cleared out a code 8, and fixed a jumpy idle by cleaning/bleeding the IACV.
However, as you can see in the video the idle is now steady but now my tach is all jumpy. (Didn't do this until AFTER the recent repairs.) Any ideas what I might have done?
Old May 9, 2013 | 03:31 PM
EL Vap133's Avatar
Default Re: Why is my tach doing this? **video**
Did you take out any fuses? Have you checked the speedo sensor to see if it is in place still? Mine was loose once and was coming out of the tranny and I had a similar issue. Another time it was a fuse a friend pulled out on accident, just don't remember which one.
Old May 9, 2013 | 03:37 PM
crxguy406's Avatar
No fuses removed, and my speedo sensor is the cable type. (which is secure.)
Old May 9, 2013 | 04:25 PM
swordofdoom's Avatar
Loose tach wire. Its getting the signal phasing out to ground and then getting the signal again. Check the blue wire for the IGN Tach.
Old May 9, 2013 | 04:27 PM
hatch89's Avatar
have you checked the wiring to/from the dizzy? if the signal is weak or broken it could cause this problem. GL
Old May 9, 2013 | 05:26 PM
Former User's Avatar
Possible bad igniter unit, assuming the blue wire tests fine.
Old May 9, 2013 | 07:06 PM
tmurph's Avatar
mine was doing it when my alternator was going out then blown up the next day....?
Old May 9, 2013 | 10:07 PM
Spug's Avatar
When mine did that years ago, it ended up being the igniter.
Does it jump all over the place if you rev it a little?
Old May 9, 2013 | 10:09 PM
BIGef's Avatar
mine was dizzy when i had that jumpy tach
Old May 10, 2013 | 03:55 AM
crxguy406's Avatar
Actually yes it does, if I quickly punch the gas a little it sort of 'sticks' then 'springs' up.
Considering the other problems I've had, this new dizzy must be defective after all. It was only $85 off egay.
I've been reading that richporter makes a good dizzy, they go for about $140 on egay, maybe worth a try?
Old May 10, 2013 | 07:28 AM
whit3tatt3dn3rd's Avatar
mine is doing the same thing... will have to look at some of this stuff and make sure.. But mines only when I'm not moving is this the same issue?
Old May 10, 2013 | 11:04 AM
Spug's Avatar
I don't remember what I went with, but I think it may have been a Cardone, worked fine.
The Cardone units are $141 on Rockauto.com
Old May 10, 2013 | 11:23 AM
jlk16188's Avatar
mine did that when my alternator died.
Old May 10, 2013 | 02:38 PM
ownedevo10's Avatar
Mine was doing that a month ago. Try taking off the distributor cap and looking at the ignitor one of the wires was hanging off and not connected which caused my jumping tach. Reconnected and problem was gone.. Hope this helps
ramco
Mar 6, 2010 07:30 PM
toolow69
Jul 9, 2009 09:15 PM
92integracer
Oct 15, 2008 12:58 PM
prelude_93vtec
Jun 28, 2007 03:00 PM
Mikey3000
Sep 6, 2006 02:32 PM
