1995 accord just died!
Old May 8, 2013 | 06:36 AM
cmfllc's Avatar
Default 1995 accord just died!
Hello, new to Honda's. i bought a 1995 accord for my granddaughter . it has been running fine till sat. i drove it around checking things out. when i got back home, it was running so i could check trans fluid, all of a sudden it died. no shudder or lope, just died. all it does now is turn over , won't start. i replaced coil, changed icm, checked all the fuses, all good, fuel pump working. i have no spark at the plugs, does anybody have any idea what could cause this. it is a 2.7 v6 190000 miles. i got codes miss firing on every cylinder. and got one that said unknown dtc. any help would be appreciated.
Old May 8, 2013 | 06:48 AM
DeadlockRiff's Avatar
Default Re: 1995 accord just died!
do you have power at the ignition coil (input wire)?
if you have power l, I would go on to the distributor itself along with checking the resistance of the ignition wire coming out of the coil to the distributor.
if no power find a wiring schematic and trace it back for continuity up to the fuse. (assuming you have power to fuse itself).
Old May 8, 2013 | 07:29 AM
cmfllc's Avatar
i will try that today. thanks
Venom564
Jun 2, 2015 09:23 AM
cheapo23
Oct 18, 2012 07:04 PM
Kris's turbo
Oct 10, 2011 10:18 AM
scorpiontank
Aug 8, 2007 06:29 PM
digital_cowboy
Classic Hondas
Jul 10, 2007 02:58 PM
