04 accord v6 blowing ignition coil fuse helppp
my friend has a 04 accord v6 she said check engine light came on flashing car was running rough she shut the car off and now it just cranks but doesnt start i check the fuses and the 15amp fuse for ignition coil was blown i replaced it and it popped right away i dont know what it could be anyone ever experience this before
Re: 04 accord v6 blowing ignition coil fuse helppp
I would check the spark plugs to see if any are loose or damaged first, mainly because that will not cost anything. Try to find out what error codes the computer has stored, know anyone with a scanner/code reader? Maybe one of the auto parts stores will lend one out to you. If the check engine light was flashing, there should be some codes stored.
theres no codes the coil wire on one of the coils on pass side rear is burnt i disconnected it and put a new fuse in went to start it and it still pops
the coil looks burnt and the wires are all burnt i unplugged it and put new fuse in and it still pops
The wires are probably melted, and shorting together, so it will probably keep blowing the fuse. You have bigger problems than I can solve, sorry. You will probably need a new wiring harness, and a new coil to say the least, but you need to find out why the wires melted, before just plugging another harness in. Hard to believe there are no codes?
I'm sure some shops would just splice the wires, but you still need to know what happened to cause it. Maybe it was the coil, maybe not.
accordhate
06-12-2019 04:53 PM
marcmichaelonas
11-07-2017 01:31 PM
