smoking
Old May 7, 2013 | 05:02 PM
HDX15's Avatar
Default smoking
I have a1991 honda civic d15b2 that i recently had head work done because I had a broken exhaust valve in cylinder 3. I had the head checked and valve seals replaced now it had blue smoke coming from exhaust. I looked down the spark plug tubes and number 3 & 4 look wet 3 is more wet. I put a paper towel in the tube and check it was oil. Could the valve seal been put on wrong.
Old May 8, 2013 | 03:00 AM
rd91sib18c5r's Avatar
Default Re: smoking
Valve seals won't cause that, you need a valve cover gasket set it will have seals for
the spark plugs.
Old May 8, 2013 | 05:43 AM
HDX15's Avatar
Default Re: smoking
Sorry there's oil in the piston cylinder not the spark plug tube
Old May 8, 2013 | 07:28 AM
4drEF's Avatar
Keyboard Humorist
Default Re: smoking
Compression test followed by leak down test.
Old May 8, 2013 | 08:03 AM
HDX15's Avatar
Default Re: smoking
Compression test was good.
Old May 8, 2013 | 09:34 AM
4drEF's Avatar
Keyboard Humorist
Default Re: smoking
That's good. So maybe nothing catastrophic has happened.
Leakdown test will help you determine if the problem is in the head or the block.
Old May 8, 2013 | 01:30 PM
HDX15's Avatar
Default Re: smoking
Can't I just put compressor air and listen where it's leaking from since I know its leaking
Old May 8, 2013 | 02:46 PM
4drEF's Avatar
Keyboard Humorist
Default Re: smoking
I guess you could
Old May 13, 2013 | 02:36 PM
HDX15's Avatar
Default Re: smoking
The compression test and leak down test revealed nothing unusual
Old May 13, 2013 | 03:39 PM
4drEF's Avatar
Keyboard Humorist
Default Re: smoking
Then you are imagining the smoke because nothing is leaking oil.
Old May 13, 2013 | 05:43 PM
HDX15's Avatar
Default Re: smoking
Going to get Myself checked tomorrow
Old May 14, 2013 | 04:30 AM
HDX15's Avatar
Default Re: smoking
Going to pull the head off and see what's wrong
houstonteamer
Sep 13, 2009 07:23 AM
1badteg
Jul 16, 2007 02:00 PM
95dc2teg
May 11, 2007 11:15 AM
Average Al
Jun 28, 2005 10:22 PM
743power
Nov 18, 2003 10:28 PM
