Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Immobilizer brake code help
Old May 7, 2013 | 11:55 AM
trapstar101's Avatar
Icon2 Immobilizer brake code help
So I had to use the immobilizer brake code to get my 07 civic to the dealership to program new keys. They now say they got the keys programmed but it is stuck in programming mode or something because I used the brake code to get it there. They had no idea what I did and have never heard about it before. Anyone familiar with this and know what needs to be done next? Thanks
Old May 8, 2013 | 06:27 PM
DELuth's Avatar
Default Re: Immobilizer brake code help
Whaaaa??? The DEALER didn't know what the brake code was? You need to use a different dealer! It should fix itself after a while, but if not, pull the backup fuse for a couple minutes or disconnect the battery and touch the cable together for several seconds.
edit: By "a while" I mean around 10 minutes. Also, if your battery is weak, the immobilizer can freak out.
rooobosmith
Dec 21, 2021 05:49 AM
Skip H
Honda CR-V & Element
Mar 10, 2019 07:59 PM
Guzzling guzzle
Dec 28, 2018 10:34 AM
Jetsa
14
Dec 14, 2009 07:50 PM
svtec
Mar 18, 2004 08:09 AM
