immobilizer help...
Old Aug 15, 2003 | 07:49 PM
svtec's Avatar
L D E S
Default immobilizer help...
has anyone had any experience with trying to start the car using the immobilizer brake code?
is there any kind of set sequence you have to follow with turning the ignition on and off?
thanks for any help...
Old Aug 15, 2003 | 08:40 PM
svtec's Avatar
L D E S
Default Re: immobilizer help... (svtec)
Old Aug 15, 2003 | 10:18 PM
HONDADNA's Avatar
Yes! but how did you get the brake code to by pass your immob. unit. The dealership should note be giving this info. to owner. This is just ment for dealership technician use. However, I can not help with this; for as a dealer tech, I can not give you this info.
Sorry!
Old Aug 15, 2003 | 10:29 PM
PHiZ's Avatar
Default Re: immobilizer help... (HONDADNA)
then why did you bother posting dumbass?
I'd like to hear more about this brake code thing, not familiar with it, I do know that you can disable this by desoldering some stuff from the ecu.
Yes it is an anti-theft measure, but also, it's a legitimate problem with doing swaps, and you know exactly how helpful the dealership is with swap questions.
-PHiZ
Old Aug 15, 2003 | 10:33 PM
PHiZ's Avatar
Default Re: immobilizer help... (PHiZ)
And twenty seconds later off of google:
The next group of vehicles will not give you a permanent transponder key. By following the directions, yes, you can start the car up and drive it for as long as you want to. As you read the directions you will understand why this isn’t permanent. First, here is a list of the seven models and the year they started to have transponders:
Acura 3.5 RL started in 1997
Acura CL & TL started in 1999
Acura NSX started in 1997
Honda Accord started in 1997
Honda Insight started in 2000
Honda Odyssey started in 1998
Honda Prelude started in 1997
Now the procedure to do them:
The procedure is known as the "Brake Code." The "brake code" is always a five digit number. First, I will give you the formula and then the "special conditions" that go with it:
1. Cut the key code into an ordinary HD-103 keyblank.
2. Turn the ignition switch on.
3. Enter the first digit of the five digit code by pressing and releasing the brake pedal the same number of times as the digit. (For example, if the first digit is five, press and release the pedal five times.)
4. Turn the ignition switch to lock and then back on. NOTE: From the time you turn the switch on, put the code in, and shut it off, you MUST do it all in less than 20 seconds.(20 seconds is a long time)
5. Repeat steps 3 and 4 to enter the second, third, fourth and fifth digits of the code.
6. After you enter the fifth digit, the immobilizer indicator on the dash will blink five (5) times meaning you can now start the car with the temporary key. While the engine is running, the immobilizer indicator will stay on. You have up to ten minutes to start the car. You can shut it off and it will restart as long as it is less than ten minutes in the off position. If you have it off more than ten minutes, you must re-enter the entire brake code. This code can be entered into the vehicle and started a maximum of ten times. After that, the computer will not allow the code to work.
Every vehicle on the Acura and Honda list, whoever you get codes from, pertaining to this list, is given two codes for every vehicle. The first is, of course, the key code and along with that, together, is the Brake Code.
Old Aug 16, 2003 | 08:29 AM
svtec's Avatar
L D E S
Thanks PHiZ, the internet is a powerful thing! I was told to use my E-BRAKE! That's probably why it didn't work -
Old Aug 16, 2003 | 09:29 AM
svtec's Avatar
L D E S
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDADNA &raquo;</TD></TR><TR><TD CLASS="quote">Yes! but how did you get the brake code to by pass your immob. unit. The dealership should note be giving this info. to owner. This is just ment for dealership technician use. However, I can not help with this; for as a dealer tech, I can not give you this info.
Sorry! </TD></TR></TABLE>
you just got owned.
so much for your privledged information from your 12 dollar an hour job.
Old Aug 16, 2003 | 06:55 PM
HONDADNA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by svtec &raquo;</TD></TR><TR><TD CLASS="quote">
you just got owned.
so much for your privledged information from your 12 dollar an hour job. </TD></TR></TABLE>
Please you drive up window fast food teller, no school learning jack *** like your dad, mimum wage earning bitch....
Five of your low paycheck does not match my one week of pay
Old Aug 16, 2003 | 07:00 PM
HONDADNA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ &raquo;</TD></TR><TR><TD CLASS="quote">then why did you bother posting dumbass?
-PHiZ</TD></TR></TABLE>
"Dumbass," it that what your mom calls you - man! I hope that's not your picture - I think you better take a second look. Oh yeah bitch! You forgot one step on your so called educated procedure - do you witch one - dick 4.
also dumbass - not all honda's uses the parking brake - plus dumb and dumber - the industry no longer uses the term " "E-brake"
Old Aug 16, 2003 | 07:38 PM
svtec's Avatar
L D E S
Five of your low paycheck does not match my one week of pay </TD></TR></TABLE>
thanks for describing your life in a nutshell.
don't bother using proper grammar, don't bother getting an education, and keep working your job that has classified information and earns you zero money.
I'll keep all of this in mind when I'm thinking of your dirty *** underneath some bitches car and she realizes that your the type of guy that never gets any ***** (due to lack of game and failure to have your ********* descended at the ripe ol' age of 25 is it)?
you are a NPGMF for life.
non
gettin
you're gay.
Old Aug 16, 2003 | 07:57 PM
HONDADNA's Avatar
non
gettin
you're gay. </TD></TR></TABLE>
Dam! was that you or your family guy? Okay, just bring your car in that you can't fix and I'll throw it at my **** pile. I bet your one of those bitches that has a body kit installed and no money to paint it, right? just say it guy, that you ride ain't much to look at just like your self. So... been ******* your cousin or sister lately? no need to be ashamed of it. Everyone told me this, man.
But any ways, keep working hard at jack's - so one day you too can have a painted body kit and perhaps have a car that is better. Well in your case maybe 10 years or so.
Old Aug 16, 2003 | 08:52 PM
PHiZ's Avatar
Makes me glad that I don't trust the dealership with my car...
Anyways, svtec, that will only start the car 10 times, and you can't turn the car off, hahaha. so I don't see what good this does ya.
I have sources that can disable the immobilizer, if you need, but you'd have to send it out.
What ecu is it, I might be able to get them to cross-ship.
-PHiZ
Old Aug 16, 2003 | 09:38 PM
svtec's Avatar
L D E S
HONDAGAY you need to knock this **** off. we all know that you are a worthless shitsack that doesn't get laid. we know you cant spell. i know that you are a piece of horse dung.
you have failed on many levels and now you can add this to the list.
just chalk it up to the immense amount of failure you have received in your life and that means that you are that much closer to ending your own pathetic life.
once again i leave you one and last final statement of advice.
quit thinking your hard. the last time you were hard was when your dad was raping you in the *** and giving you a reach around.
i will not respond to anymore of your belligerency because your mom is busy giving me and my friends road head.
goodbye...
Old Aug 16, 2003 | 10:25 PM
HONDADNA's Avatar
sure son! bitches like are fun talking **** to. Look dude, your acting tooooo much of a bitch. sorry lady - I should have known that I was dealing with a female. It's to bad your not close to seattle - man if you're a guy, I would love for you to say some **** like that to my face. But again, I don't pick on little bitches too.
But, whats up with this getting ***** **** - come on guy is that the best you got? man, I can't believe that your still mad about me and your sister and my dog ******* your MAMA.
I quess that's alright guy - but we both know that the only ***** you get is your hands - dude which one is it, the right or the left? no, it must your pet dog.
Man! I must have pissed you of alot. You must be a female, right? if so, I'm sorry . I know that a gentle men like myself should not be saying thing like " YOUR ACTING LIKE A LITTLE BITCH" OR "DADDY MUST OF DRESSED YOU UP A MORE THEN A FEW TIMES." However, they do have the local police department for that kind of stuff. Well if you want a 800 number, just go to google and type in:My daddy is dressing me up and now I'm a bitch like my daddy. That sounds about right, right?
Well I guess I was some help to you
Old Aug 17, 2003 | 03:12 AM
eg_type_r93's Avatar
ha ha ha ^^^^^^^
Old Aug 18, 2003 | 01:33 AM
fu*kfaceC1EH2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDADNA &raquo;</TD></TR><TR><TD CLASS="quote">sure son! bitches like are fun talking **** to. Look dude, your acting tooooo much of a bitch. sorry lady - I should have known that I was dealing with a female. It's to bad your not close to seattle - man if you're a guy, I would love for you to say some **** like that to my face. But again, I don't pick on little bitches too.
HONDAFAG. I've never seen someone get SO OWNED before in my life. I love the fact that you claim you work at a dealership in Renton, which one is it? Kia? Possibly a used Daewoo dealership? Well friend, I would love to know which one you do work at, because I am VERY close to Renton and I would love the chance to come and pay you a visit. Don't bother learning how to spell; maybe dropping out of middle school wasn't such a good choice afterall, was it? And now let me guess.... you'll reply something along the lines about my MAMA, or something great, and you WON'T man up enough to list in this post where you work. If you decide to not be such a *****, TELL US WHAT dealership you work at. If you lack the amount of ball needed to tell us, don't post again. I would hate to see you get owned again like svtec owned you. Don't worry about telling me anymore besides the place you wash cars and change garbages, because once I get there, I'm very sure I won't have a problem finding your 5th grade graduate ***. OWNED. PERIOD. Post your work, or don't post again.
Old Aug 18, 2003 | 05:25 AM
nevin's Avatar
Retard got........ OWNED
Old Aug 18, 2003 | 04:41 PM
HONDADNA's Avatar
Default Re: immobilizer help... (fu*kface95hatch)
[QUOTE=fu*kface95hatch]
HONDAFAG. I've never seen someone get SO OWNED before in my life. I love the fact that you claim you work at a dealership in Renton, which one is it? Kia? Possibly a used Daewoo dealership? Well friend, I would love to know which one you do work at, because I am VERY close to Renton and I would love the chance to come and pay you a visit. Don't bother learning how to spell; maybe dropping out of middle school wasn't such a good choice afterall, was it? And now let me guess.... you'll reply something along the lines about my MAMA, or something great, and you WON'T man up enough to list in this post where you work. If you decide to not be such a *****, TELL US WHAT dealership you work at. If you lack the amount of ball needed to tell us, don't post again. I would hate to see you get owned again like svtec owned you. Don't worry about telling me anymore besides the place you wash cars and change garbages, because once I get there, I'm very sure I won't have a problem finding your 5th grade graduate ***. OWNED. PERIOD. Post your work, or don't post again. [/QUOTE
where the hell did you come from bitch! I don't remember saying **** to you dumbass!
let see if you really got the ***** to come and see me then, well do you!
there is my work address: 1331 stewart St. Seattle, Wa.
this is my new place of work - So, I guess l'll be see ya' .
Mon - fri come after 5pm I need a warm up!
Old Aug 18, 2003 | 04:48 PM
HONDADNA's Avatar
I gave mine - Now can you give yours - if not, go somewhere else!
Old Aug 18, 2003 | 05:52 PM
nevin's Avatar
I want video coverage of this brawl if it ever goes down.
Old Aug 18, 2003 | 06:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDADNA &raquo;</TD></TR><TR><TD CLASS="quote">[QUOTE=fu*kface95hatch]
Mon - fri come after 5pm I need a warm up!</TD></TR></TABLE> Expect a visit soon. Make sure you get a good night's sleep, and wear boots. I'm off this week so it will be a fun time for you. Don't take this lightly.. I'll see you soon. OWNED
Old Aug 19, 2003 | 06:24 AM
HONDADNA's Avatar
like i said "I'll be seeing ya'" Can't wait!
Old Aug 19, 2003 | 01:01 PM
^owned.
Old Aug 19, 2003 | 03:01 PM
HONDADNA's Avatar
still waiting, waiting, waiting. owned ha ha ha but still waiting, still waiting.
Old Aug 19, 2003 | 03:28 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDADNA &raquo;</TD></TR><TR><TD CLASS="quote">Yes! but how did you get the brake code to by pass your immob. unit. The dealership should note be giving this info. to owner. This is just ment for dealership technician use. </TD></TR></TABLE>
Wrong!!! Check your September 1999 service news and you'll see that part of the reason for the brake code is to get a customer who has lost one of their keys home.
