Please help me, need car for school
Old May 6, 2013 | 02:23 PM
Kid-jdm-teggy's Avatar
Default Please help me, need car for school
Hi, im 17 years old and i need help diagnosing my car's problem. It started to jerk hard in 1st and 2nd and pretty hard in the other gears. (Jerk as in, when you are in 1st gear at 1500-2000 rpm and let off the gas completely and get back on it). The feeling of being lunge forward and backward. I would put it in 1st and i get it moving without taking off my feet off the gas but it still does it. Could this be the clutch giving out because to get the car moving, i would have to let the clutch pedal go out pretty far before it catches. I tried searching but i dont know for sure what could be causing it, distributor? Clutch?
Old May 6, 2013 | 02:43 PM
B_Swapped93's Avatar
Default Re: Please help me, need car for school
All Honda(90's) are like that with the clutch pedal. sounds like your cap and or dizzy rotor are worn out. have a look
Old May 6, 2013 | 02:53 PM
Any signs to look for? If it helps, my rpm guage goes all over the place when i give it 1/2 throttle
Old May 6, 2013 | 04:06 PM
DirtyDA9's Avatar
Ignitor in the distributor.
Old May 6, 2013 | 04:15 PM
fcm's Avatar
fcm
Old Fart
A tach that jumps around is a symptom of a ICM going bad, or connection problems in the distributor.
MM&Y of car would help, image will be of a 94 RS...
Remove the cap, [#2] careful with the cap gasket, [#9] pull the rotor, [#3] by removing the set screw, [#11] then remove the leak cover, [#6].
You can now access all the terminal/plugs/connections to the ICM, [#8] and coil, [#12], make sure they are ALL clean, [no corrosion] and tight, if loose, unplug and "crimp" the terminal a little tighter and reconnect.
If there are signs of corrosion, [moisture] inside the cap or on any component in there, the cap gasket is NG and needs to be replaced. 94
Old May 6, 2013 | 04:43 PM
1995 integra ls. All stock. So could the ignitor going bad cause the car to jerk? I know it can affect the rpm readings but what about the jerking? Thanks
Old May 6, 2013 | 04:55 PM
fcm's Avatar
fcm
Old Fart
If the ICM is bad/intermittent, so will the spark, bad/intermittent spark = misfiring = "jerking". 94
Old May 6, 2013 | 04:58 PM
Ok, thanks so much. I will go to o'reilly to pick up a replacement. I should have it done by saturday and will update for people who might have the same problem. Thanks again
Old May 7, 2013 | 12:17 PM
pimpwagon's Avatar
Don't just buy parts. do the testing to see if it's what you actually need...
Old May 8, 2013 | 03:31 PM
Ok, today i was taking it for a drive to see if it was still jerking. It drove just fine so i drove it around for like 30 minutes and it was still fine. So my question is, should i replace the dizzy or maybe that wasnt the problem.
Old May 8, 2013 | 04:09 PM
TunerN00b's Avatar
What you should do is inspect and test any part before blindly replacing it.
Old May 8, 2013 | 05:18 PM
How do you test the distributor and its components? Visually inspect it?
Old May 8, 2013 | 05:39 PM
S2BumpsticksGSR's Avatar
Step 1:download your vehicle's service manual from my signature to a/your laptop. @1000pgs of your cars info/testing procedures/diagrams, etc. Step 2:find your distributor's specs/troubleshooting in the manual. If you can't download the pdf, go to your parts store and order a book for your car. It will greatly benefit you and you will learn quite a bit about your car just from one book. Good news is there's multiple publishers of these books.
Old May 8, 2013 | 06:01 PM
Thanks, but do you know what page the troubleshooting of the dizzy is located? 1000+ pages is alot to be searching through lol
Old May 8, 2013 | 06:06 PM
TunerN00b's Avatar
Resistance check on the ignition coil would be a start. Visual inspection and cleaning of the cap and rotor wouldn't hurt. Just follow the instructions in the service manual.
Old May 9, 2013 | 07:32 AM
Ill help you this time, but get to know the book a bit. Distributor would be in the ignition system- section 23-87.
phelpsj2
Aug 10, 2009 09:30 PM
EF-Honda91
Jul 8, 2006 12:48 AM
Jmumblez2001
May 28, 2006 09:09 AM
slowkaos
Dec 25, 2004 10:49 AM
