Cel wont turn on!
I recently bought my son a 1993 civic dx (1.5 16 valve) as his first car. When I bought it I didn't notice that the check engine light did not turn on when I started the car. The car starts and runs fine but I can't get it smogged because the cel does not turn on when the key is turned. I checked the wiring from the ecu and the bulb itself and their fine. I noticed some spliced wires near the ecu but can't figure out what the problem is. Any ideas? Thanks in advance !
Post clear pictures of the spliced wires near the ECU.
I think you need a P06 ECU. Verify by checking the label on your ECU behind the passenger kick panel. Also make sure to match the ECU to the transmission - auto versus manual.
The block is marked D15B7.
The reverse lights work but the oil pressure light does not. I also noticed that a wire is cut just above the oil filter.....oil pressure sender maybe.
I would post photos but I can't seem to figure out how.....maybe because I'm still a trial member for a few more days.
D15B7 = P06 ECU
You definitely want the oil pressure light working, so repair the sender unit wire. However, that's not causing the CEL problem. Based on your collective information, the ECU is almost certainly bad and doing all the tests in the diagram is worthwhile and should confirm this diagnosis.
Upload your pictures to PhotoBucket and then paste the IMG code for each picture into your post.
hatchmanej6
16
Aug 14, 2013 12:48 PM
slowcrxsib16
Jan 17, 2007 03:41 AM
