Temp gauge going crazy...
Old Oct 23, 2002 | 07:19 AM
USDM 4G VTEC's Avatar
Default Temp gauge going crazy...
k my temp gauge its going loco big time....
on idle it reads ok.. i rev the engine on a stand still and its ok....
now once i start rolling and going, the gauge goes crazy.... everytime i shift the gauge goes all the way down... as soon i keep reving on a gear it goes up to normal... it happens every time i shift.... or if i gun and let the gas go on a gear....
my question is,,, wich sensor its really the one that sends the signal to the gauge?? maybe the coinector its loose... is it the oe on the head underneith the Dizzy with a butllet conector?? i need to check this soon its get anoying jejeje
Old Oct 23, 2002 | 07:26 AM
EF_LSVtec's Avatar
Default Re: Temp gauge going crazy... (JDM EF9)
i wonder if your water pump is going out...I remember that happening to me on my 88 accord years ago...temp gauge would fluctuate especially when I rev motor.
Old Oct 23, 2002 | 07:33 AM
Default Re: Temp gauge going crazy... (EF_LSVtec)
the weird thing its that it does it only while reving on a gear... out of gear everything its good... i guess it goes with momentum of engine
Old Oct 23, 2002 | 07:37 AM
89 CRX SI's Avatar
i hitnk it could be the plug needs to be cleaned on the back of the cluster. The on on the passs side above speedo cable. pull it out and clean it replace tightly then go.
Fixed my wiered temp problems. mine would go up every time you are rolling and use turn signal left haha
Old Oct 23, 2002 | 08:23 AM
red civic standard's Avatar
Default Re: Temp gauge going crazy... (89 CRX SI)
check your engine grounds...especially the one coming off the negative terminal of the battery
Old Oct 23, 2002 | 09:06 AM
Superhatch's Avatar
Default Re: Temp gauge going crazy... (red civic standard)
Your car is about to blow up!!!!! J/k check your grounds...could be something like alternator buzz?
-Jake
Old Oct 23, 2002 | 09:52 AM
2_Jay_Z's Avatar
I'm thinking it could be the water pump also. When the water pumps went out on both of my parents vehicles, the temp was HOT!!!
Old Oct 23, 2002 | 09:57 AM
lilrex's Avatar
Default Re: Temp gauge going crazy... (88'_CRX_Si_Dude)
Or you might just need to burp your coolant?
Old Oct 23, 2002 | 05:28 PM
ahc'monracing's Avatar
try checking you temp gauge sensor. it might be a loose connection. my did the same thing, following the rpm's of the car. it doesn't hurt to check.
Old Oct 23, 2002 | 05:40 PM
Monty's Avatar
To answer your question, its the one below the distributor. below the vtec solenoid on a b-series, I think its a green plug, the sensor has a black terminal.
hth,
Monty
BTW - I can get you a part number if you need it, I just bought one.
[Modified by Monty, 2:42 AM 10/24/2002]
HondaH22A
Aug 27, 2007 01:57 PM
HondaTeg95
Feb 15, 2006 05:24 PM
Boofster
Dec 6, 2004 03:18 PM
sung
Aug 10, 2004 12:03 PM
