Need 2001 Accord Window Help
Old May 5, 2013 | 08:50 AM
jon062495's Avatar
Default Need 2001 Accord Window Help
My passenger window was not working. So today i replaced it but the motor does not work still. I checked all the fuses and nothing seems to be the problem, can someone help me out? I don't know what it could possibly be
Old May 5, 2013 | 01:21 PM
HondaAccordKen's Avatar
Default Re: Need 2001 Accord Window Help
#1, is the on-off switch on drivers door on? If so do you have a meter or test light.
Both motors wires rest at and must be at ground with motor unplugged. With light or meter test from known POS+ wire like at door lamp to each wire. The ground comes from door switch and goes through passengers switch. If not at motor plug check to see if it's at the two wires coming from drivers at passengers switch.
With digital meter connect both probes to the plug going to motor and you should see 12+ one way and 12- the other.
Hope this helps.
rhdins
Oct 19, 2012 02:38 PM
Hallgren
Jul 16, 2012 10:32 PM
hialeahzbg
Sep 20, 2011 09:32 PM
Erik95LS
Dec 19, 2001 06:39 PM
