fs 96 honda civic hatch gsr
Old May 5, 2013 | 08:20 AM
Freek's Avatar
Default fs 96 honda civic hatch gsr
Asking/Offering Price: 4000 obo
Email Address/Phone Number (optional): 66055302ninethree
Zip Code: 65301
Pics: below
Item Description:96 dx hatch b18c swap
For auto listings these are also required in addition to the fields above.
Year: 96
Make: honda
Model: civic
Mileage: 200,xxx
Title Status: clean
Color Exterior/Interior:silver / grey
Transmission: 99-00si
Drivetrain:b18c
i have fs only no trades price is 4000 obo
car has; 96-98 ex harness and cluster, spliced ait sensor plug to harness onlything cut on harness. tokico hp blues with gc coil overs and bwr lower control arms. innovative solid mounts with red inserts, and new oem si tbracket. jumper harness and chipped p28. stock ls header with megan catback system. oem ls flywheel with gsr clutch mileage unsure purchased from freek.
at the time of the swap i added new cv shafts, clutch slave and master cylinder, tires, everything added and swap have less then 6k miles.
the bad is common ek window issues hard to roll up and down, header and exhaust was welded together using a flex pipe shop refused to fix, no headliner fabric it was falling down, clearcoat is peeling and does have some dents and scratches, also no ac at all.
third gear does grind occasionally which im 100% its the shift linkage, trans was purchased from unique image from kcsr and guaranteed, also hot tanked inner and outer case and had buddy at shop inspect gears everything looked good. running royal purple in trans, mobile1 in engine, doesnt burn leak or consume any oil in engine. also have some extra parts to go with it.
if you have any questions or offers text 66055302ninethree i will check site but texting will be faster
civic95hbvtec
Nov 24, 2007 08:18 PM
SrT4u2nV
Feb 4, 2007 08:52 AM
E_k_9 1_p_t_8
Dec 19, 2005 02:23 PM
hatch101
Sep 16, 2003 05:16 PM
