3 Questions: Engine, Electical and Cosmetic
Old May 5, 2013 | 05:21 AM
CivicInUse22's Avatar
Default 3 Questions: Engine, Electical and Cosmetic
First off I found this piece in my trunk after the rebuild and have no idea where it goes. Car is a 1998 civic ex. It's a mount of some sort, looks like maybe radiator mount but idk. It is the picture with the Silver piece.
2nd - The picture where I am holding that relay type thing where it used to be hooked up to an alarm system is confusing me. Not sure if it IS part of the alarm system or was just tapped into. I did rip out the alarm system but wasnt sure if that was part of it or not. The other picture is me holding the wires that connect to it that go through to the harness. Is this piece important or not? Cruise and power door locks dont work and I feel this may be why.
3rd - How do you get all that nasty corrosion off of the ram air intake?
Old May 5, 2013 | 12:21 PM
murphy95si's Avatar
I was actually wondering what that bracket was too. maybe someone can help?
Posted from Honda-tech.com App for Android
Old May 5, 2013 | 12:39 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
Default Re: 3 Questions: Engine, Electical and Cosmetic
that might be a factory exhaust manifold bracket, I'm almost sure it is, usually bolted above the oil pan to the block and supports the downpipe
Old May 5, 2013 | 01:38 PM
Former User's Avatar
Yep...it's called the exhaust mounting stay.
Old May 5, 2013 | 02:25 PM
nub's Avatar
nub
The relay you're holding is the starter kill relay from the alrm system you removed. You can leave it or remove it completely.
The thick white and red wire will go the cut blk/wht starter wire. Most are connected to the normally closed portion of the relay so the car can start if the alarm fails (removed in your case).
It doesn't have anything to do with your cruise and lock issue.
Old May 5, 2013 | 05:39 PM
Awesome thanks for the replies! Guess I dont need that bracket sense I have an aftermarket system. And ill be sure to take that relay out. It just looks gross sitting in there dangling. Im gonna try to use a paint/rust remover grinder to take off the corrosion on my intake. Also have quite a bit on my strut bar.
Otis B. Firefly
Audio / Security / Video
15
Feb 27, 2015 09:49 AM
w1ck3dR
Honda Civic (2001 - 2005)
Dec 10, 2008 09:45 PM
MeekalLS
14
Jun 14, 2006 11:36 AM
snatch
Apr 28, 2005 08:16 AM
