ZC DOCH HELP !
just swapped in a zc doch into my 91 si
got it to start but it starts ROUGH and the idle climbs so high I have to turn it off
I am running an SI wiring harness
Sensor issue?
if any one in the phoenix area thinks they can help I would much appreciate it and even pay
PM7 intake manifold
pm6 ecu
I traded my daily driver for this car and now I am stranded.
Picked up the motor when my stock d16 blew a connecting rod
Sensor issue?
PM7 intake manifold
pm6 ecu
The Distributor wiring does not match with an SI stock wiring.
Rework the Wiring to match, or it will run rough.
Also check the spark plug wires to dizzy cap it might not be hooked up right.
Any codes flashing?
Timing this engine is a real BISH!
Any codes flashing?
okay so here is another update, I redid the wiring harness to the distributor and got it to start, ran a rough idle but it was low this time. I think it has to be a wiring issue at this point. The timing seems to be correct but I wouldn't know how to tell for sure.
Now the car wont start and the ECU is flashing constantly!
it tries to turn over and sounds so close!
The codes I had before the ECU was doing this were 6,7,9,10,14
But I had sensors not hooked up that are now, what is causing the ECU to flash nonstop along with the check engine light! I have tried two different pm6 ECUS and both do the same but one just doesn't flash because I believe the led is out or it may be broken.
If you know how to set the car at TDC at the crank, just look at the camgears. The two inner hash marks should be pointed directly at one another (level). Also, "up" arrows will be slightly tilted inward at eachother but otherwise upright. After you verify this you can verify ignition timing but you'll need a timing light.
You have a wiring issue with the dizzy.
Make sure the plug wires are set up right. #1 runs on the bottom then clockwise #3, #2, #4 on the cap. Think of it as the Letter "t" depending on how the dizzy is positioned.
I seem to always have code 9 no matter what I do with the dizzy and exhaust cam sensor on the OBD0 dizzy. I am about to ditch it this week for an OBD1 dizzy and get rid of the exhaust cam sensor.
Now that I think about it. I think the previous owner might have installed the dizzy in backwards
douglaslovin
Feb 14, 2009 08:32 PM
drjondurst
Apr 5, 2003 11:58 PM
