D16z6 intake manifold
Old May 3, 2013 | 10:55 AM
Hyunbs's Avatar
Default D16z6 intake manifold
Hello, i am replacing a custom intake manifold on my d15b z6 head . The previous owner had this weird large custom one and its been giving me problems since none of the vacuum lines were connected. So my main questions is what are the steps on installing the z6 manifold? I have a p32 stampped manifold i bought to install it. All sensors are intact . Just need to know what the steps are. I searched for the install but people just put up "everything just bolts on" any help is much appreciated .
Old May 3, 2013 | 12:24 PM
grumblemarc's Avatar
The Grumpiest
Default Re: D16z6 intake manifold
It does just bolt on. What is it exactly that you're stuck on? Have you attempted the swap yet?
Old May 4, 2013 | 10:06 AM
Hyunbs's Avatar
The lines and stuff. Only thing im stuck at is the one hose that leads from the intake manifold through it to the bottom. Ill take a pic
Hyunbs's Avatar
Also, i am disconnecting everything right bow and was wondering how to release the fuel pressure before taking off the fuel rail?
Old May 4, 2013 | 12:21 PM
Marvin1985's Avatar
That line that goes thru the manifold is the pcv hose and connects to the pcv. Pop your fuse box and pull out the fuel pump relay. Start the car. It'll die in 2 seconds. There fuel pressure relieved
Old May 4, 2013 | 02:22 PM
Hyunbs's Avatar
Thank you!!
Old May 4, 2013 | 02:55 PM
dseriesboulder's Avatar
Question for my own head... When is De pressurizing the fuel system required? I got new tb, im, headers and cold air and I know the mechanic didn't do it. Runs runs fine. I got a cel for running rich on bank 2 tho. Anyway... Sorry to jack the thread.
Old May 4, 2013 | 06:40 PM
Marvin1985's Avatar
When working on anything fuel related that involves disconnecting a fuel source or line.
Old May 4, 2013 | 09:15 PM
Hyunbs's Avatar
Np, how much did the mech charge for all that
lv2racehondas
Honda CR-V & Element
Mar 15, 2019 11:01 AM
Rsuave24
Mar 27, 2014 09:14 PM
Traser
Nov 4, 2006 05:31 PM
RACEPAK
11
May 31, 2005 09:34 AM
ImporttRacerr555
Dec 14, 2003 07:00 PM
