Coil-(Stuck)Over
Old May 2, 2013 | 02:39 PM
Skelley1980's Avatar
Default Coil-(Stuck)Over
So I'm trying to raise the front end by the Coil-Overs. Use the spanner wrench and the whole Coil-Over will spin in place under the spring. So I try to tighten the top nut, again spins the whole thing. Threads are cleaned and lubed up. Use a wrench to hold one in place and use the spanner wrench to twist the other nut, and the spanner wrench bends on me. I'm thinking these must be some cheapies. What to do?
Old May 2, 2013 | 02:44 PM
dirty19's Avatar
Ridin Dirty in Cali
Default Re: Coil-(Stuck)Over
get some better more sturdier wrenches, for starters.
the wrenches tend to be on the cheap and flimsy side for most cheap coilovers.
grumblemarc's Avatar
The Grumpiest
Sounds like some Ebay joints. The SPANNER wrench bends? That's screams low to no budget right there.
Is it a single perch or locking perches?
Old May 2, 2013 | 02:56 PM
2 locking. This was all bought, not built. Dude had the front end slightly lower and I'm bottoming out on tight turns with hills.
Old May 2, 2013 | 05:44 PM
drummerklm666's Avatar
odd deal i have here i have a 92 civic so im trying to sell the car a man comes to look at it and pulls a sparkplug wire while it was running now it wont start i tried the computer i tried the igniter and now main control i still have no spark the tricky part is when i put my light tester on the spring of my coil and crank the car the lights flash on the tester but it does not arc to anything i have to hold it to the spring in the coil any help please
Old May 2, 2013 | 05:55 PM
TunerN00b's Avatar
Go get 2:
and use one on the lock nut while holding the spring perch with the other.
They're useful for all kinds of things, and everyone who does any work on cars or around the house should never be without a few (oil filter, coolant hoses, water pipes, shower heads, anything that doesn't take a standard open ended wrench).
Old May 4, 2013 | 01:04 PM
Strap-Wrench Genius!!
umair
17
Sep 4, 2008 08:26 AM
krashoveride
Honda Civic (2001 - 2005)
Mar 2, 2008 02:13 PM
WARCOVENANT
Jan 1, 2006 07:41 PM
implayaz9
Suspension & Brakes
Oct 31, 2005 10:52 PM
dc2monkie
Honda S2000
Jun 17, 2004 08:59 PM
