What else should i order with my CTR or ITR cams???
Old Oct 23, 2002 | 05:53 AM
DeDonDeRosa's Avatar
Default What else should i order with my CTR or ITR cams???
what else do i need to buy with my CTR cams or ITR cams for my 97
GSR its really important and what brand of anything else do u guys recommend or can i just buy the cams and put them in ??? please help me out
[Modified by DeDonDeRosa, 2:54 PM 10/23/2002]
Old Oct 23, 2002 | 06:46 AM
CTR94Joes's Avatar
Default Re: What else should i order with my CTR or ITR cams??? (DeDonDeRosa)
You need to do the valve train if you plan on revving past 8500 rpms.
Old Oct 23, 2002 | 06:51 AM
Default Re: What else should i order with my CTR or ITR cams??? (CTR94Joes)
its gonna be stock rev 8100 so can i just install the cams ??? without like doing springs and retainers ?? right ??
Old Oct 23, 2002 | 09:06 AM
WAFFLES's Avatar
si senior
Old Oct 23, 2002 | 09:41 AM
redline201's Avatar
i get some good cam gears skunk 2 maybe
and a apexi VAFC
and have it dyno tuned to get the most out of your setup
Old Oct 23, 2002 | 02:08 PM
Default Re: What else should i order with my CTR or ITR cams??? (redline201)
i have the VAFC i would just need the cam gears then
Old Oct 23, 2002 | 05:55 PM
ImportechPerformance's Avatar
you should really upgrade your valve springs.....
This is simple all you need to do is buy the ITR intake valve springs
Your GSR intake valve springs are the same as ITR exahust valve springs
so buy moving those to the exahust side and installing the new ITR intake springs you will now have an extra protecion against valve float(which is not good).......
Good thing for you i have the ITR intake valve springs for sale BRAND NEW still in the bag.....for cheap.
Ps i just did this and trust me i feel alot better knowing that this is how Honda intended it to be
You do not need the valve retainers cuz if you search a lil more you will find out that gsr ITR and 99 si retainers are ALL THE SAME so just buy my ITR springs and be on the safe side and keep your valve train happy
[Modified by TheRedSkoolingBus, 7:56 PM 10/23/2002]
Old Oct 23, 2002 | 09:01 PM
b18cDC2's Avatar
Default Re: What else should i order with my CTR or ITR cams??? (TheRedSkoolingBus)
So how much are u selling ITR intake valve springs for?
Old Oct 25, 2002 | 08:16 PM
redline201's Avatar
is this true with a 2nd gen b16a also ???
how high can i rev if i do this
thanks
Old Oct 26, 2002 | 12:31 PM
redline201's Avatar
ttt
Old Nov 9, 2002 | 09:16 AM
Popkorn's Avatar
I'm currently installing CTR Cams and valvesprings in my 1999 GSR motor, what would my redline be at with this setup? And do you guys know what RPM my powerband will peak at?
endlessjdmeg
Aug 12, 2007 08:24 PM
sihatchyvtec
May 14, 2004 08:47 AM
slogsr
11
Sep 22, 2003 01:56 AM
genetsang
Jun 10, 2003 07:57 AM
Ovl55rag
Jan 3, 2003 08:41 AM
