ctr cams in gsr???
Old May 11, 2004 | 07:47 PM
sihatchyvtec's Avatar
Default ctr cams in gsr???
first off does ne one here have them, and if so how great is the difference? anyway.. i plan on getting them or type r cams. if i do do i need to get valve springs if i buy ctr cams. but dont plan on bringing it up past the 8 grand redline of a gsr.. let me no thanx.. jim
Old May 11, 2004 | 08:34 PM
darrinbrewer's Avatar
Default Re: ctr cams in gsr??? (sihatchyvtec)
1st , do some archive searching in the integra forum..but here's some info:
ctr cams are identical to 2000 us spec itr cams.
all itr/ctr exhaust cams are the same, but pre-00 itr have 3 degrees less duration
valve spring issue:
gsr intake valve springs are the SAME PARTS AS ITR EXHAUST VALVE SPRINGS
move your intake springs to the exhaust side, and buy ITR intake valve springs
you'll be running dual valve springs on all valves..
a skunk2 manifold and a chipped p28 would be next on the list.
as the itr cams are made for vtec after about 5800-6000 rpm,and 4400 vtec on a skunk2 manifold absolutly sucks, it just bogs down til around 6k rpm
(assuming you have a nice flowing header and intake system already)
hope this helps you out, and search around..you;ll find everything you need..
Old May 11, 2004 | 09:25 PM
Slain's Avatar
nice explanation....tho this topic has been beaten like a seal
Old May 11, 2004 | 09:40 PM
riceball777's Avatar
i use to have ctr cams
and i think they suk
i felt no difference at all. just like a intake or a header. felt like a bolt on.
but my rs machine cams made a hell of a difference over the ctr cams. made real power can be felt big time and made the engine sound real mean.
oh and rs cams are equilvent to jun 3's and sk stage 3's
Old May 11, 2004 | 10:16 PM
carcala's Avatar
Default Re: ctr cams in gsr??? (riceball777)
i have ctr cams in my car. its a good upgrade from the stock gsr cams. Car pulls alot harder especially on top end. I also have the skunk 2 manifold but run the stock ecu. like darrinbrewer said u have to raise the vtec crossover 5500-5700 which i will be doing as soon as i get hondata.
Old May 11, 2004 | 11:44 PM
redGSRguy's Avatar
I got them put in and my car is quite a bit louder. Makes me feel faster. Don't think I actually got much power though.
Old May 12, 2004 | 05:16 AM
sQwiReL bOi
Guest
Posts: n/a
juss get some skunk2 stage 1s or 2s. ull be happier.
Old May 12, 2004 | 11:50 AM
Default Re: (sQwiReL bOi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sQwiReL bOi &raquo;</TD></TR><TR><TD CLASS="quote">juss get some skunk2 stage 1s or 2s. ull be happier.</TD></TR></TABLE>
thats my future plans....swap in some 1s or 2s and out with the ITR cams...
can stage2s run on ITR valve springs? i know stage1s can, but i'd like to make the jump up to the 2s..
Old May 12, 2004 | 04:22 PM
Slain's Avatar
i believe you will need a better set of valvesprings. i've seen some stage2's redlining quite high
Old May 12, 2004 | 04:29 PM
boostinb20vtec's Avatar
if you keep the factory redline you are fine...but then again, why up the powerband and keep a lower redline!?!?!
Old May 12, 2004 | 06:25 PM
luvinmyGSR's Avatar
Default Re: (boostinb20vtec)
just make sure u get them tuned
Old May 12, 2004 | 06:26 PM
crawdad689's Avatar
if you plan on going FI, stay w/ stage 1's
Old May 12, 2004 | 11:39 PM
PiNoY GsR RaCeR's Avatar
Default Re: (luvinmyGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luvinmyGSR &raquo;</TD></TR><TR><TD CLASS="quote">just make sure u get them tuned</TD></TR></TABLE>
Yes that is true.
Old May 13, 2004 | 09:09 AM
greaseball's Avatar
with only ctr cams, SX fpr, and cam gears i made 168whp. i think the ctr's are a great cam for a street motor. this is on a 99 gs-r btw.
Old May 14, 2004 | 08:47 AM
Default Re: ctr cams in gsr??? (darrinbrewer)
yeah so i should def get rid of my p72 ecu and get a chipped p28? is it even worth gettin cams w/ a p72 ecu w/ 4500 vtec changeover
PUREMONEY
Jan 28, 2009 09:56 PM
bl1tzk1213g
Jan 29, 2008 06:56 AM
phantoman
Nov 12, 2003 07:49 PM
1fast-hatch
Jul 23, 2003 06:51 AM
GSR -97
Nov 26, 2001 09:25 AM
