99 civic dx - how check timing belt?
Old May 1, 2013 | 07:05 PM
greeen ranger's Avatar
Default 99 civic dx - how check timing belt?
just bought a 99 civic dx. i want to do a well inspection myself of the car and have drove it for 2 weeks already with no problems at all beside the transmission being a little grinding, anyways i wanted to open up my timing belt cover tmrw so i know more or less in how long i got to change it. would appreciate the help or TIPS!
Old May 1, 2013 | 07:30 PM
hwyix's Avatar
Default Re: 99 civic dx - how check timing belt?
Timing belts are usually changed out by mileage or age not by visual inspection.
Old May 1, 2013 | 07:32 PM
true but i have no record on the last change.. i would like to take a look at it because if it is loose i have heard its time to have it replaced or if it looks weared out and small rips in it.
Old May 1, 2013 | 07:34 PM
Former User's Avatar
If you have no record, then just replace it. Do the water pump and tensioner at the same time.
hwyix's Avatar
I would just change it then. If you have two cars you can inspect everything first, timing belt water pump, bearings etc.. if you only have one car I would just replace everything and be done in a day.
Old May 1, 2013 | 07:37 PM
im no mechanic.. so ill have to find a guy who does an at home job and hope for the best he does not mess up on the timing. i wouldnt trust my self replacing a timing belt + water pump + tensioner
Old May 1, 2013 | 07:39 PM
hwyix's Avatar
Just go to shop. I would not mess with some backyard hack.
Old May 1, 2013 | 07:46 PM
got any rough estimate? ive heard 300-400 for full timing belt replacement that include pump and tensioner..
Old May 1, 2013 | 08:14 PM
Learn to do it yourself:
http://www.civicforums.com/forums/23...t-96-00-a.html
Old May 2, 2013 | 06:50 AM
strategy400's Avatar
How many miles are on the car? If it's over the first t-belt change mileage but not to the 2nd you could open the valve cover/top timing cover and see what brand of belt it is. If it's not a honda OEM belt then it's been changed at least once. If it is, change it to be sure. You can also look at the teeth to see if there's any wear, but with your timing belt its a critical part so the safest bet is to change it. The hardest part is getting the crank pulley bolt loose. You'll need a foot lb. torque wrench to re-torque it. You'll need an inch lb. torque wrench for the water pump bolts.
See the link RonJ posted.
Old May 2, 2013 | 08:35 AM
hwyix's Avatar
Originally Posted by RonJ@HT
That is a nice write up.
I would advise NOT doing your timing belt job unless you have been wrenching on cars for while and have good understanding on how an engine works. ( ignition timing, mechanical timing, interference engine )
There is nothing hard about a timing belt if everything goes just like how the book says. That is almost never the case. Would you know what to do the if the timing belt slipped off and cams slipped and moved,etc.. That is just one example. Lots of little things crop when removing that much junk. Doing a timing belt in the bigger scheme of thing does not save you that much money. Your car goes 90k to 120k before you need to replace it. That is like every eight years. Learn to do thinks that come up more often like brakes/rotors/coolant/transmission fluid. Much less things go can wrong and there simple to figure you.
I would recommend shadowing a mechanic friend doing your timing belt or just pay a shop and be done with it.
Old May 5, 2013 | 03:49 PM
Yes i have no plans at all doing the timing belt myself with the little experience i have. any how, i got to disable the 7.5a which resets my ECU and it still shoots the same 3 codes i first checked. which are listed as one of the first replies of this thread. about the o2 sensor.. ik i can buy it off the junk yard but how do i know if its working before buying it?
Old May 5, 2013 | 04:14 PM
No codes listed in this thread.
Old May 5, 2013 | 04:33 PM
whoops wrong thread then, but i got codes p1381, p1509, and p0135. i have the repair manual to tell me what to do with the codes and one of these codes r the o2 sensor, just wanted to know how to get one in good working condition.
Old May 5, 2013 | 04:36 PM
The codes don't tell you what specifically is malfunctioning. They just tell you that there's a problem in those three circuits. You need to do some electrical troubleshooting.
Start by checking whether those three sensors are plugged in or whether some sensor connectors have been swapped.
What engine and ECU do you have?
Old May 5, 2013 | 04:49 PM
d16y7 engine and im assuming the computer that goes with it? dont know what ecu it has
Old May 5, 2013 | 04:52 PM
You must be sure of the engine you have. Here's how to check the head and engine codes:
https://honda-tech.com/forums/showpo...5&postcount=12
For the ECU, remove the passenger kick panel to see the label on your ECU. Post the full ECU code. The stock one should be a P2E.
http://www.phearable.net/tech/wiring/ecus.html
Old May 5, 2013 | 04:59 PM
yes, i for sure know the engine is a d16y7 because of the stamp. now the ecu is kinda difficult. i recall multiple codes on it? is there a specific one with a specific line or something around the code to indicate the indentification of the ecu?
Old May 5, 2013 | 05:01 PM
You are reading the block code, but people swap engine heads, so it would be wise to know what head you have on the D16Y7 block.
Post pictures of the ECU labels you see.
Old May 5, 2013 | 05:07 PM
pics coming up give me a sec
Old May 5, 2013 | 05:09 PM
Old May 5, 2013 | 05:11 PM
Pics don't work.
Upload pics to PhotoBucket and then paste the IMG code in your post.
Alternatively, use the advanced editing feature to attach the pics.
Old May 5, 2013 | 05:13 PM
let me kno if u can see it
Nope
Old May 5, 2013 | 05:16 PM
there ya go
