Help identifying part and how to fix
Old Apr 30, 2013 | 04:58 PM
educontech's Avatar
Default Help identifying part and how to fix
Hello,
The image below is of under the hood of my 97 Honda Accord which I arrived home to coolant spewing out of the circled spot with the arrow denoting the direction of the air being blown when I raised the hood. I put coolant in the radiator and the reserve tank as it was completely empty. Can this be repaired easily and what would be recommended? I simply can't afford another shop fee if I can do this myself. Thank you.
Old Apr 30, 2013 | 05:07 PM
charliccs's Avatar
Default Re: Help identifying part and how to fix
the hose that you circled is the AC hose and don´t have nothing to do with the coolant or the reserve tank of the radiator...
Old Apr 30, 2013 | 05:11 PM
educontech's Avatar
I obviously have shown my ignorance and am appreciative of your assistance. Is it okay to drive the car as long as I don't run the AC?
Old Apr 30, 2013 | 05:22 PM
charliccs's Avatar
I think you don´t have any problem... even if you turn the ac on if the system don´t have freon r134 the compressor wont turn on...
but you have to check the coolant tank and radiator because if was empty you could have a leak in the radiator or a hose... check the temperature gauge...
sorry for my english...
Old Apr 30, 2013 | 05:29 PM
educontech's Avatar
I just rechecked and there is a small hole in the upper water hose directly behind the circled area. I taped the hole really good and will get a replacement hose. I'm glad that this is a repair I can make.
Old Apr 30, 2013 | 07:24 PM
jdowen2's Avatar
You need the A/C system evacuated before you replace the hose and then recharged.
shm91
15
Sep 24, 2013 07:42 AM
maddmike24
Jul 31, 2011 08:17 PM
WillEat4F00d
Aug 19, 2007 03:20 AM
Smeeg Heed
Aug 10, 2004 08:18 AM
suaveshab
Jun 4, 2004 09:39 AM
