Eg hatch idle/rev limiter problem
Hey everyone I got a eg hatch
It wasn't running so replaced dizzy an worked
Now it sounds like a lawnmore , also won't let me
Go past 4k rpm. Anyone can please give me some help
Thanks-
Thanks-
There has to be something not connected or plugged in the wrong spot or the distributor is bad or cap and rotor just basically something isn't right what ECU codes is it throwing what ecu is it what motor etc.
bad cap and rotor won't show up as a code as said finish the tune up new cap and rotor are a must if you did find/get it at a junk yard
Thanks everyone for the reply.
the rev problem was my ecu cables mixed up.
the lawnmore problem was 2 bad spark plug wires.
now its swapped b20 with gsr head (:
When I got the car my harness was messed up
Cut an lose wires everywhere even by the ecu harness
So I just connect 2 loose wires it had an problem was fixed.
jrhcivak
Jun 18, 2012 12:38 PM
