94 Civic fuel injector problem plz help
Old Apr 29, 2013 | 10:20 AM
jaap_15's Avatar
Default 94 Civic fuel injector problem plz help
Hey guys, I have a 97 gsr motor in a 94 civic and I ran into a problem, I was hoping you guys could help cause I've searched but I couldn't find what I was looking for, my problem is the my injectors in cylinder #1 and #2 seem to stay open because its idling rough but when I disconnect fuel injector plug #1 or 2 nothing happens but if I disconnect #3 or #4 it will want to stall, I'm getting power to all 4 fuel injector connectors, and I already swapped the injectors from cylinders 3 and 4 into 1 and 2 to make sure it wasn't the injectors, but its still the same. All this happened when I installed my turbo setup, the injectors are RC 650 cc and I also have hondata s300, thanks guy I appreciate any help
Old Apr 29, 2013 | 02:47 PM
jaap_15's Avatar
Default Re: 94 Civic fuel injector problem plz help
Any suggestions?
Old Apr 29, 2013 | 04:38 PM
jaap_15's Avatar
Bump
Old Apr 29, 2013 | 05:03 PM
B_Swapped93's Avatar
Have you done a pulse test ? also when it does this rough idling is it ALL the time or just when the car is stationary ? i have/had something similar https://honda-tech.com/forums/showth...3139855&page=4 from post #83 to about 96(or so). is most likely an electrical vs "physical" problem one
Old Apr 29, 2013 | 06:19 PM
jaap_15's Avatar
Thanks I looked over that linked, very good information and I didn't do a pulse test I'll have to go buy one tomorrow so I can do the pulse test, but I did check the connectors with a test light with the key on and I have solid light from the test light on the injector connector
Old Apr 29, 2013 | 06:21 PM
jaap_15's Avatar
And the rough idle is most of the time, I can't really even drive it cause it'll stall on me
Old Apr 29, 2013 | 06:29 PM
when you say "key on" do you mean in the 2(II) postion ? it must be done when the car is running just like the pulse test. and when you say connector you meant at the ECU right ?
Old Apr 29, 2013 | 06:36 PM
EsotericImage's Avatar
Retired Moderator
how old are the RC's?
Old Apr 29, 2013 | 06:54 PM
jaap_15's Avatar
Sorry I meant the the key on 2(II) after the fuel pump primes, I also tried it when the car is on, and I haven't check them at the Ecu I checked them at the fuel rail
Old Apr 29, 2013 | 06:55 PM
jaap_15's Avatar
They have less the 300 miles on them, I had them running before I installed the turbo
Old Apr 30, 2013 | 02:17 PM
jaap_15's Avatar
I checked the pulse today and injector #1 brown wire and injector #2 red wire get very dim pulses at the ecu pins and the other 2 injectors get bright pulses, what could it be?
Old Apr 30, 2013 | 02:20 PM
grumblemarc's Avatar
The Grumpiest
Maybe a little backstory. This started happening when?
EG2_KING
May 10, 2009 04:52 PM
ArdaMK2
Sep 29, 2008 08:50 AM
BB1vtec
May 20, 2006 09:32 AM
PowderB16
23
Feb 26, 2005 05:14 AM
nexgen91
May 15, 2004 08:53 PM
