wheels size for type r
Which would you go and would I have to worry about rubbing... the car is lowered maybe 1.5-2 finger gap
16x7 +45mm or 16x7 +40mm
I guess really I want to go +40...
Tire size is going to play a roll in rubbing or not too. With 205's on the +40 you'd probably be fine.
I'm at +35 with a 215 and had to roll mine so that I could run less camber without rubbing.
Stick around +42 to +45 and you will be fine. Personally, I would not go +40. It'll probably be ok, but the other will give you tire size options without worry of rubbing anywhere.
