VTEC PROBLEMS
Old Apr 28, 2013 | 08:04 AM
colorfulej1's Avatar
Default VTEC PROBLEMS
I have a 96 type r swap with a built head and RMF header on a 96 civic. I'm using a d16 stock exhaust wich is like 1.5in . will that cause it to run wierd? it seems to bog down when vtec hits. it won't go past 5500rpm (vtec), it hits as if that were the rev limiter . help please!
Old Apr 28, 2013 | 08:15 AM
Ryan96GSR's Avatar
Default Re: VTEC PROBLEMS
Any CEL's?
The stock exhaust is pretty restrictive. You probably want 2-2.5".
Old Apr 28, 2013 | 08:24 AM
ganna check CEL's . and should a 00 civic si exhaust be good?
Old Apr 28, 2013 | 08:35 AM
Ryan96GSR's Avatar
That should be okay. Stock exhausts are generally more restrictive, but that is certainly better than what is on there now.
Old Apr 28, 2013 | 08:40 AM
Grenadian's Avatar
A bigger exhaust is recommended but a small one shouldn't restrict it from going past a certain rpm.
Check your oil level and cels.
Old Apr 28, 2013 | 08:53 AM
oil level is good, need an oil change. Ganna check CEL's right after work. do yu guys think it could be something with fuel ?
Old Apr 28, 2013 | 09:09 AM
Grenadian's Avatar
Your injectors could be too small, vtec solenoid bad, iacv not hooked up right. When did this start happening?
I read some people's cluster not reading right. One guy said he it showed 5500rpm but it was revving to 8k.
And built head and 1.5" exhaust? You need a bigger one for sure XD
Old Apr 28, 2013 | 09:25 AM
injectors arent to small cause it worked before with the small exhaust. & cluster isnt bad it cause when engine its not warmed up vtec doesnt hit and goes to 9000rpm. an vtec solenoid i think its good cause vtec does engage but then hits a rev limiter like sound. i started happening slowly, vtec would hit and seem like it would loose more power every time. but now it just seems to rev or loose injectiong maybe?
fuel injection**
Old Apr 28, 2013 | 09:32 AM
Grenadian's Avatar
You had the built head before the problem running the small injectors? And make sure you don't have the iacv plug switched with something else.
Old Apr 28, 2013 | 09:35 AM
yes head was built before problem, & ganna check that.
Old Apr 28, 2013 | 09:48 AM
grumblemarc's Avatar
The Grumpiest
In the time you are taking to post to this thread you could have gone out to the car and pulled the codes.
Old Apr 28, 2013 | 10:03 AM
im at work
Old Apr 28, 2013 | 10:10 AM
The Grumpiest
So you keep saying, yet here you are posting.
When you get the codes pulled we can better help you.
Old Apr 29, 2013 | 05:16 PM
harms_is_back's Avatar
Check the dizzy
Old May 2, 2013 | 03:56 PM
okay i checked my CEL's and it gave me code 0 wich is as soon as i jumped it and turned on the ingition the light came on and stayed on. its a bad ECU? my car starts thoe. just wont go past 5500rpm (vtec)
Old May 2, 2013 | 04:21 PM
how do i check dizzy?
Old May 2, 2013 | 05:09 PM
xile6's Avatar
vtec oil pressure sensor.
Ground it out and take it for a drive.
Old May 2, 2013 | 06:51 PM
civicexkid1's Avatar
in one post your saying vtec isnt working and then you say it does. does vtec happen at all???? vtec should happen at 5800 in a b18c type-r or 4500 in a gsr b18c1 or 6000 in a b18c5.
please tell us all that is done to the engine...you say you have a built head: is it with stock parts again or do you have cams and all that? if you dont you never mentioned anything about having a chipped ecu and tune and then thats a problem?
you said it had a d16 in it before i know there are a few wires you have to extend to make fit right and work correctly also/
Old May 2, 2013 | 06:58 PM
i just re-read your post and tried to understand what you were saying...... are you saying that at 5500rpm's it cuts in and out like a rev limiter? please stop refuring to 5500rpm as vtec!!!!!!!!!!!!!! if you have a check engine light on your ecu is in limp mode which wont let the car rev past a certain engine speed which is 5500 for you to prevent engine damage!
so if your car doesnt go past 5500rpm your ecu is in limp mode and wont let vtec activate either to prevent damage etc.
Old May 3, 2013 | 11:06 AM
cvcrcr99's Avatar
What are you tuned on.
Old May 3, 2013 | 11:58 AM
nealnanoHX's Avatar
Really? Wow just dont say anything, you have no clue. The stock injectors are fine, Car will still run to redline even with no Vtec and a bad IACV will not cause the car to cut at 5500K. Op check for codes ans what ECU are you running? Yes you should have a larger exhaust but the stock one will not cause this issue.
Old May 5, 2013 | 09:29 AM
its a B18c with crower stage 2 cams and valve train. I AM NOT USING ANY D16 WIRING. only D16 exhaust. MY VTEC HITS, BUT AS SOON AS IT DOES IT HITS SOME SORT IF REV LIMITER. I HAVE A CHIPPED P28 WITH TYPE R BASE MAP. BUT THE PROBLEM JUST HAPPENED RECENTLY. IVE RAN WITH THAT ECU FOR LIKE A COUPLE YEARS. IDK THE EXACT RPM VTEC HITS BUT ITS SOMEWHERE AROUND 5500-6000RPM.
Old May 5, 2013 | 09:30 AM
HOW DO I GET OUT OF LIMP MODE ? i have stock injectors with inline pro fuel rail
Old May 6, 2013 | 08:38 AM
Reset ecu but if it really is in limp mode, it'll go back in limp mode within a day or sooner since something triggered it to go in limp mode and obv won't get out until you find out why or get it foxed
