Distributor oil leak!!
Did you lube the o-ring with oil before you put it in? If you did, chances are the seal is fine and you most likely have a crack in the distributor housing itself. I've heard of people patching them up with JBweld or something like that but you're best bet is to replace the whole thing if it's cracked.
If you didn't remove the shaft from the distributor, you replaced the external o ring. Internal/external is in reference to their location on the distributor, not the head. Most people don't even know there's one inside the dizzy.
http://www.google.com/imgres?q=inter...&tx=111&ty=114...
that little black seal inside there . thats the one.
