96-98 headlight city light mod issue
Old Apr 25, 2013 | 10:50 PM
Cap'N Chronic's Avatar
Default 96-98 headlight city light mod issue
So I've decided to take on the task of installing city lights in a set of spareheadlights I had layong around. The headlights are oem honda off a 97 civic. Got sylvania 168 amber bulbs, and bulb sockets from a 97 civic, they were originally license plate light sockets. Got the socket to fit in the citylight hole on the back of the headlight and I drilled a hole on the headlight lense. But when I put the socket through the blub doesn't reach through to the lense? I'm stumped. I will upload pictures in a bit.
Old Apr 25, 2013 | 11:03 PM
apexi_rsx's Avatar
Default Re: 96-98 headlight city light mod issue
Upload pics so we could possibly give u an idea what to do next...
Old Apr 25, 2013 | 11:34 PM
Old Apr 25, 2013 | 11:37 PM
I'm assuming the bulb is supposed to poke through a little so that it will shine on the entire housing. Think I could get some LED bulbs that are a bit longer that would fit through?
Old Apr 26, 2013 | 12:11 AM
http://floridahondacrew.com/showthread.php?t=10902
Just came across this DIY thread. This guy used rear marker sockets from an integra, which look a lot longer than the license plate sockets I'm using. I'll try to find a set of these somewhere.
Old Apr 26, 2013 | 12:26 AM
apexi_rsx's Avatar
i know on m 06 type s the city lights are on the top not the bottom ... im sure its alil late now to try as u have already cut the hole....
Old Apr 26, 2013 | 08:07 AM
Well that spot in the back that I drilled out is the factory position for city lights in EK headlights. I've been told those sockets I have should work, they just aren't long enough for some reason.
Old Apr 26, 2013 | 09:01 AM
kiickz4dayz's Avatar
I had the same problem. You need extended sockets part number 33304-s04-g02
Old Apr 26, 2013 | 09:39 AM
typerlegend's Avatar
The sockets that came with my JDM lights are much longer to accomodate the spacing between the reflector bowl and the housing...
Techy
Sep 21, 2008 07:49 AM
Ruben19
Nov 1, 2006 08:21 PM
EK99hatch
Sep 7, 2004 05:40 PM
silverd16y71996
Mar 23, 2003 08:11 PM
HAcEx01
Jan 6, 2002 04:06 PM
