96-98 headlight city light mod issue
So I've decided to take on the task of installing city lights in a set of spareheadlights I had layong around. The headlights are oem honda off a 97 civic. Got sylvania 168 amber bulbs, and bulb sockets from a 97 civic, they were originally license plate light sockets. Got the socket to fit in the citylight hole on the back of the headlight and I drilled a hole on the headlight lense. But when I put the socket through the blub doesn't reach through to the lense? I'm stumped. I will upload pictures in a bit.
Re: 96-98 headlight city light mod issue
I'm assuming the bulb is supposed to poke through a little so that it will shine on the entire housing. Think I could get some LED bulbs that are a bit longer that would fit through?
http://floridahondacrew.com/showthread.php?t=10902
Just came across this DIY thread. This guy used rear marker sockets from an integra, which look a lot longer than the license plate sockets I'm using. I'll try to find a set of these somewhere.
i know on m 06 type s the city lights are on the top not the bottom ... im sure its alil late now to try as u have already cut the hole....
Well that spot in the back that I drilled out is the factory position for city lights in EK headlights. I've been told those sockets I have should work, they just aren't long enough for some reason.
The sockets that came with my JDM lights are much longer to accomodate the spacing between the reflector bowl and the housing...
Techy
09-21-2008 07:49 AM
silverd16y71996
03-23-2003 08:11 PM
