B18b ls swap checklist
Old Apr 25, 2013 | 09:36 PM
97hxStreetSweep's Avatar
Default B18b ls swap checklist
Planning on a local ls swap from a d16y5 97 hx, I need a checklist of everything I'm going to need THE FIRST TIME.
92-95 Ls motor and tranny, stock clutch and flywheel
acura integra 92-95 halfshafts
p72 or p75 ecu prechipped hondata ordered from Phearable.net
obd2a to obd1 jumper harness
Let me know if I'm missing, or need to be recommended of something.
Also another question, what's a reasonable price on a used ls motor and tranny? (it's jdm, no crank sensor or egr, I would estimate 60-100 thousand miles on motor)
Old Apr 25, 2013 | 09:55 PM
FeelTheBass's Avatar
Default Re: B18b ls swap checklist
B series shift linkage. Prices for a used jdm b18b with LS tranny around here go for around 1000-1200 bucks, the full swap on hmotors is like 2000 plus shipping.
Old Apr 25, 2013 | 09:58 PM
bladesz42's Avatar
don't forget your em1 t bracket!
Old Apr 25, 2013 | 10:18 PM
T bracket? Is that an engine mount?
Also, any ecu wiring in question? Do I need a 92-95 wiring harness?
Old Apr 25, 2013 | 10:33 PM
Cancel that, I just found a good post about this.
https://honda-tech.com/forums/hybrid-engine-swaps-18/%2A-%2A-obd1-b-series-engine-into-obd2a-obd2b-civic-integra-%2A-%2A-1972711/
I'll ask questions if need be, and will start a thread about the build when it begins.
Old Apr 25, 2013 | 10:52 PM
myersfaxy's Avatar
Old Apr 26, 2013 | 09:18 AM
kiickz4dayz's Avatar
Engine
Tranny
Half shaft
Axles
Obd2 alternator
Obd2 dizzy
Shift linkage
Si driver post mount
Rear si t bracket
Obd1 p75 ecu with step down harness
If you want ac use
Crv ac bracket with single cam compressor or
Si ac bracket with b series ac compressor
benchmade
Nov 29, 2008 04:00 PM
wannakno
Jun 10, 2003 09:42 PM
steveo97civic
Jan 23, 2003 08:44 AM
todds94teg
Jul 16, 2002 07:00 AM
yellowbastrd
Nov 15, 2001 09:42 AM
