Misfiring, Red inside my dizzy???
Old Apr 25, 2013 | 03:22 PM
Crxh22ajdm's Avatar
Default Misfiring, Red inside my dizzy???
OK so one day I decided to wash my engine with a pressure Gun. I cover all the intake and vacuum stuff, injectors, and Egr. I let it dry for like an hour, then I drive it after 2 minutes of driving the engine died at a stop sing. It when to the normal rpm then when all the way to 0, I turn it back on and the rpms where at 100 making a misfiring. Well I make a turn back home and I star looking, well my spark plug wires where all with water. Inside the engine so I replace them with new wires and nothing. I open the dizzy and it had like red stuff all over. Do I have to replace it or can I get parts from other dizzy?? And rebuild it?? My engine its a JDM h22A obd1 with internal coil
Old Apr 25, 2013 | 03:24 PM
Crxh22ajdm's Avatar
Default Re: Misfiring, Red inside my dizzy???
SORRY FOR MISSPEALLING MY FIRST LANGUAGE IS NOT ENGLISH
Old Apr 26, 2013 | 06:22 AM
snobordboy's Avatar
Moderator
What is the red, a fluid, plastic chunks, something else?
Old Apr 26, 2013 | 02:05 PM
holmesnmanny's Avatar
If I had to guess you probably fried your distributor. I always wonder why people would want to risk pressure washing their car.
Old Apr 26, 2013 | 05:17 PM
Crxh22ajdm's Avatar
Its like red dust. its not fluid.
Old Apr 26, 2013 | 05:21 PM
Crxh22ajdm's Avatar
I have wash over 9 B-H series engines and this is the first time it happens. my car still turns on. Do I have to replace the complete dizzy or what
Old Apr 28, 2013 | 01:14 PM
I would replace the entire distributor if it was me.
Old Apr 29, 2013 | 08:23 PM
Crxh22ajdm's Avatar
I found the problem. Replacing the entire dizzy is not necessary. Can anyone upload picx for me my phone can't upload picx to here. I will explain what the problem is, maybe thus can help someone else in the future.
Old Apr 29, 2013 | 09:14 PM
Crxh22ajdm's Avatar
OK the h22A internal coil, the shaft its bad. I took the dizzy apart and the shaft its like grinding it feels hard, so I had an F series dizzy and use the F series shaft into the H. But car didn't start at all. So u put everything to TDC and the rotor doesn't point to Cil #1 it points a lil bit up. So NOW WE ALL KNOW THAT THE F SERIES SHAFT DOESN'T WORK ON THE H SERIES DIZZY. Does anyone knows what other shaft will WORK on the H22A dizzy?
b20vtec crx
70
Aug 15, 2011 08:43 PM
maggot13
Apr 8, 2009 12:44 PM
SL!M
Paint and Body
Jul 8, 2007 04:00 PM
RacerXintegra2k
Jul 23, 2002 10:36 AM
