Where to source small velocity stacks
An internet search has not turned up really small velocity stacks for my intake project, maybe someone on HT knows of a source. They need to start at ~30mm and open up to about 45mm while staying ~35mm tall.
Back story: I am building a custom intake manifold for my 1987 CRX Si. The engine is in the EW family of pre D series engines and there is no support for these engines in the aftermarket. No, I do not want to "just do a swap."
The intake on the fuel injected EW engine is actuall two parts bolted together. The plenum is seperate from the runners. I plan to leave the runners and create my own plenum. Inside the plenum, at the throat of each runner, will be these small velocity stacks.
Please email me if you know of a source for small velocity stacks.
Scott
cbstd@hotmail.com
Scott
cbstd@hotmail.com
Once upon a time I emailed them with no responce..... Don't know if anybody else has had luck with them. I would try and find somebody in the states if I were u.
Mike
Mike
Have a plug done in a lathe and use a hydralic press to make your own out of pipes.
Or do above to get cones. Make solid rod cirkles and weld to the cones and mechine/sand everything smoth.
Another aussie company that was always good with supplying and shipping http://www.jntperformance.com.au/
I've ordered from Velocity of Sound. Price seemed high, shipping took 5 weeks. Parts were BEAUTIFUL.
Beware that while the material is high quality they're pretty thin. Totally weldable but requires a deft hand on the TIG.
neverstop
24
Mar 23, 2010 06:00 PM
