H22A Rattling Sound?! *Video Inside*
Old Apr 23, 2013 | 02:39 PM
flexoffender's Avatar
Default H22A Rattling Sound?! *Video Inside*
Hey guys, i noticed a rattling or vibrating sound coming from the driver side of my engine bay the past few days, thinking it could possibly be a valve problem (timing/valve spring?) i've attached a video of the car idling, hope someone with more knowledge than me could pinpoint what may be causing it, thanks in advance H-T!
Old Apr 23, 2013 | 02:54 PM
98vtec's Avatar
moderator emeritus
Default Re: H22A Rattling Sound?! *Video Inside*
Mileage? Timing belt been done?
The autotensioner for the timing belt are notorious for failure on these engines.
www.kstuned.com sells direct replacement manual tensioners
Old Apr 23, 2013 | 03:21 PM
138,000ish now, timing belt was replaced around 95,000, the noise seems to be coming from the top end...hard to pinpoint though, i don't recall it happening when i had my timing belt/water pump changed beforehand.
1armed1's Avatar
Mine sounded some what like that when my stock tensioner failed.
I got lucky and the belt did not skip.
Old Apr 23, 2013 | 03:22 PM
Fliptard's Avatar
adjust your valves and see if that helps.
Old Apr 24, 2013 | 02:45 PM
austinftwxd's Avatar
my prelude has been making a similar sound coming from the alternator lately it could possibly be that
Old Apr 24, 2013 | 03:40 PM
integra_101's Avatar
mine sounds the same. changed timing belt and tensinor. gone. I highly reccomend the kstuned.com one. i ordered it from there.
Old Apr 28, 2013 | 11:12 AM
*UPDATE* it was coming from the crank pulley, apparently it's loose and now the bolt is seized up and won't come out to replace it, looks like whoever replaced it previously cross-threaded it or something :-\
Old Apr 28, 2013 | 11:17 AM
heat it up and put some penetrant oil
Old Apr 28, 2013 | 12:44 PM
thanks, i'll give it a go, was reading all kinds of threads on various ways to get that bolt off, seems like it's pretty notorious for being a difficult one.
Hawkerdude
Oct 31, 2016 05:30 PM
gamblezhang
Nov 17, 2005 07:07 AM
ham
Aug 2, 2005 05:17 PM
petrv
Mar 1, 2004 10:32 AM
petrv
Mar 1, 2004 09:56 AM
