Removing snap ring HKS SSQV III
Old Apr 23, 2013 | 10:26 AM
NZXTInerTia's Avatar
Default Removing snap ring HKS SSQV III
So I managed to get a full set of hard piping and an HKS SSQV 3 BOV for $150.00 shipped to my door. When they drilled the hole to mount the flange (flange like attachment device utilizing a snap ring) they left a ton of burrs. Then I would just like to clean it up all together off the piping piece.
The catch is, the snap ring is missing one of the eyelets that you would put a snap ring pliers onto. Any suggestions? Thing is kicking my ***..
Old Apr 23, 2013 | 11:19 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Removing snap ring HKS SSQV III
Pull up one side and walk it out. If that won't work, pry the closed side first and then work the "eyed" side. There isn't really any tricks, you just need to get creative with some common hand tools.
Old Apr 23, 2013 | 11:52 AM
citrus3000psi's Avatar
You can try getting a larger pair of pliers like this:
http://www.harborfreight.com/hand-to...set-38598.html
specifically the ones with the 90 point. Grind down one point so it fits inside the eyelet. You should be able to grab the whole pipe while pulling the eyelet out. Have a friend put a flat head under the eyelet once its pulled out, and then walk the snap ring the rest of the way.
Old Apr 23, 2013 | 03:09 PM
xile6's Avatar
post a pix but you could try to drill a small hole to grip it.
Old Apr 23, 2013 | 07:27 PM
paulzy's Avatar
I usually walk out snap rings that break like that. They will come out with some work, the tension on snap rings aren't too bad.
aleks77
Apr 8, 2007 03:04 PM
redboost10
Nov 12, 2003 12:44 PM
dirtySOHC's
Mar 2, 2003 02:21 PM
TurboDC4
Jan 29, 2003 01:49 PM
curiousgpnoy
Jul 18, 2002 11:09 AM
