94 ls misfire no cel
Old Apr 22, 2013 | 07:55 AM
double0's Avatar
Default 94 ls misfire no cel
Idles ok when it misfires only drops maybe 20rpm so small you cant tell on gauge. New plugs wires cap rotor fuel filter. Unplugged each plug one at a time all 4 had a big change in idle all have spark no vac leaks egr good. What could cause this minor misfire and not a check engine light higher rpms the bigger the mis unless im full throttle.coolant is good no problem there temps all good. Only use premium dont matter where i go. No change in idle with weather. Seafoam helped a little but not enough.
Old Apr 22, 2013 | 08:40 AM
S2BumpsticksGSR's Avatar
Default Re: 94 ls misfire no cel
Clean out throttle body very good, spraying intake cleaner in while operating throttle by hand. Also pull your pcv out and clean. You should probably clean iacv, too.
SMP142
Mar 18, 2012 07:50 PM
tegra2G
Feb 12, 2011 08:07 PM
buzlink
10
Aug 28, 2009 11:00 AM
b18c1dc2
Nov 17, 2006 08:18 PM
dafunkdawg
Apr 29, 2002 11:31 AM
