85mm Copper O-ring Head Gasket
Old Apr 22, 2013 | 06:53 AM
Muckman's Avatar
Moderator in Chief
Icon2 85mm Copper O-ring Head Gasket
I need to bore my sleeved B18c block to 85mm and we want to copper Oring it to ensure head gasket seal. Can I run a standard MLS head gasket? Anything special required for copper Oring?
Old Apr 22, 2013 | 11:51 AM
twkdCD595's Avatar
Default Re: 85mm Copper O-ring Head Gasket
For a copper o-ring block you just use the standard OEM mls gasket.
To my knowledge the only time you need to do anything like a copper HG is when you do a stainless o-ring setup with a corresponding receiver groove in the head.
Someone correct me if I am wrong.
Old Apr 22, 2013 | 01:37 PM
carbon fiber coupe's Avatar
im copper oringed my builder used a 1mm over standard mls oem gasket....
Old Apr 22, 2013 | 01:46 PM
Muckman's Avatar
Moderator in Chief
The catch is I need to run a thicker gasket to restore deck height which means Cometic. They say their MLS is not recommened for Orings. But then again neither is OEM. Both are viton coated MLS.
Old Apr 22, 2013 | 02:22 PM
92cxturbo's Avatar
y not run a oem gasket with extra layers from another oem gasket?
Old Apr 22, 2013 | 02:32 PM
Muckman's Avatar
Moderator in Chief
You'd rather peice two head gaskets together than run a Cometic? I ran a Cometic before at 450hp and had no problems. Of course that was a flat deck without Orings.
Old Apr 22, 2013 | 07:00 PM
popwars123's Avatar
I believe that the Cometic gaskets have a fire ring on the bottom side which will interfere with an o ring. You may want to look at the underside of the cometic to see. If not you may end up with sealing issues.
Old Apr 22, 2013 | 09:09 PM
LocoJoe's Avatar
Muck, I run a .065 cometic on the 85mm B16, nothing bad to report. Just toss it in, torque and re torque hot and thats it for me. Hope it helps something...
Old Apr 23, 2013 | 04:18 AM
Muckman's Avatar
Moderator in Chief
popwars123 the fire ring is a different type of gasket than the MLS.
Nice thanks Joe! Thats what I needed to hear.
Old Apr 23, 2013 | 04:32 AM
LocoJoe's Avatar
Forgot to mention i got copper o rings on the sleeves also.
Old Apr 6, 2018 | 11:25 AM
0c00l's Avatar
Sorry to revive but did this turn out ok? Im in the same situation and right now my machine shop is telling me if they bore and hone the block (85mm) which Darton east sleeved and O-ringed for me there will only be .0015 left on the side wall of the sleeve? this has me concerned because this is a big boost application. I know people have done this and I just got off the phone with Darton they said if I dont like it I can send the block back and they'll replace the sleeves without O-rings.
jetspeedz
Apr 1, 2018 07:26 PM
Eghatchgsr8
Sep 19, 2014 02:24 PM
chasmataz
Jul 25, 2010 08:35 AM
sickerhatch
Apr 16, 2005 10:14 AM
BlackGSR
Feb 26, 2002 06:52 AM
