1994 integra water temp sensor
Old Apr 21, 2013 | 11:57 AM
anthonye77's Avatar
Icon2 1994 integra water temp sensor
I recently had a problem with my car overheating; I then changed the thermostat which solved the problem. The check engine light was on though and I checked the codes and it was saying the water temperature sensor was the problem. I checked to make sure the fans worked by jumping the wires and they did so I replaced the water temperature sensor, and now the fans come on; but the check engine light is still coming on and indicating its the water temperature sensor. But if I let the car warm up and then turn the car off and back on the check engine light doesn't come on. I'm not sure what the problem is; any help would be appreciated.
Old Apr 21, 2013 | 12:45 PM
n0thin_2z_here's Avatar
Default Re: 1994 integra water temp sensor
See if this helps at all.
http://www.docspal.com/viewer?id=twkpfxqb-3128331
Old Apr 21, 2013 | 01:03 PM
B_Swapped93's Avatar
You re-set the ecu right ? bleed the coolant sys also ?
Old Apr 21, 2013 | 04:42 PM
HondaPartsHero's Avatar
Technical Hero
Which one of these did you replace?
Old May 21, 2013 | 05:54 PM
anthonye77's Avatar
The fan switch
Old May 21, 2013 | 08:21 PM
IN VTEC's Avatar
The fan switch isn't monitored I/O in the OBD system. The TW sensor is monitored.
Hondadude1234
Dec 9, 2012 08:47 AM
97milanoLS
Jan 13, 2011 06:56 PM
OneBornOfLight
Mar 3, 2009 11:08 AM
SiDonny
May 3, 2005 02:35 PM
vtecaccord 1
Dec 7, 2004 05:59 AM
