Help for 92' Honda Prelude Cylinder Head Rebuild
I have a 92' Honda Prelude that had a timing belt break and consequently it bent two exhaust valves.
I replaced the timing belt, the balancer and tensioners, machined the head and got new valves and guides and finished rebuilding it but now it won't start.
The engine is unique with a 2.2 block and its always had the 2.3 dual overhead cam head but I've never had a problem with it starting or running.
I have no spark and both the ignition coil and distributor were tested and passed. Does anyone have any advice or guesses as to what the issue is?
Yeah, i havent checked the thermostat but the valves were adjusted and not only have i tried the screwdriver to ground method but even the injectors are not firing.
i tried replacing the igniter, then the whole distributor and got nothing.
maybe something is not plugged in? aka thermostat maybe
