Installing manual rack into 99 Ex Coupe...issues with steering joint
Old Apr 20, 2013 | 04:17 PM
MiniRacer26's Avatar
Default Installing manual rack into 99 Ex Coupe...issues with steering joint
I am trying to install a manual rack into my 99 Ex Coupe, I am using part #53040-S04-A01.
BOX, STEERING BOX
53040-S04-A01
96-00 CX 3DR
96-97 DX 3DR
96-97 DX 2DR
Everything bolted up fine, and it seemed to go without a hitch, but the steering joint is too large to fit over the shaft that comes out of the rack. You can flip it around and the end that goes on the column shaft fits. Do they make a joint that is 3/4" on both ends that will allow me to both this up, or do I need to buy another column? I am trying to get away from the power rack because this is in a race car. I have swapped out the D16y8 for the F20B 2 liter ( blue top JDM engine).
Old Apr 20, 2013 | 04:38 PM
92lxsleeper's Avatar
Default Re: Installing manual rack into 99 Ex Coupe...issues with steering joint
yup, you need the joint for a manual rack
Old Apr 20, 2013 | 04:41 PM
honda p# 53323-SM4-013
Old Apr 20, 2013 | 04:49 PM
That will allow me to use my steering column that is in the car, and the new rack? Any other changes or should this do it? Thanks for your feedback
Old Apr 20, 2013 | 04:56 PM
yes. i went through the same situation doing a rhd swap into my older cx hatch. going from non to power. had to get the ujoint for a power steering model
Old Apr 20, 2013 | 05:01 PM
Thanks
Old Mar 14, 2014 | 09:13 AM
IntegraTypeR's Avatar
Originally Posted by MiniRacer26
Thanks
you are very lucky to get that rack. recently that particular part (53040-S04-A01) has been discontinued and its not available anymore now!
Kevin Mason
Mar 6, 2016 11:13 PM
james_moore
Feb 22, 2012 11:52 AM
uscivicmc
10
Apr 18, 2011 05:07 AM
blackGSRcoupe94
Jul 25, 2010 07:53 PM
1337 Si
23
Apr 9, 2004 12:25 PM
