Cx steering rack into ex
Old 04-17-2011, 01:09 PM
uscivicmc's Avatar
Default Cx steering rack into ex
Does a 2000 cx hatch manual rack bolt right into a 2000 ex coupe?
Old 04-17-2011, 02:10 PM
GDD Member
slomofo's Avatar
Default Re: Cx steering rack into ex
Yes, but is this just to get rid of your power steering? You can get two plugs and stick it in your regular steering rack's power steering holes.
Old 04-17-2011, 02:34 PM
uscivicmc's Avatar
yea it is but its too late for plugs, I took the lines off when i put the lsv-t in and left them open and now the rack has like two inches of play in it. so i'm just gonna replace it with a manual rack.
Old 04-17-2011, 02:40 PM
scythe88's Avatar
the manual rack have different "gearing" to them too dont they? cause i found it more difficult to turn my plugged PS rack than my dedicated manual rack.
Old 04-17-2011, 02:49 PM
ReDHaTcHyGuy's Avatar
it will still get tight over time since there is no oil flowing through it.. if u have the opportunity its best to swap a manual rack in..
Old 04-17-2011, 03:48 PM
Seagull Management
94EG8's Avatar
Usually you loop the lines with a breather rather than plugging the lines
Also, since when do you post in tech
Yep, manual rack turns easier than a depowered power rack. To swap in a manual rack you need the subframe and lower joint/knuckle from the manual steering column.
Old 04-17-2011, 04:43 PM
uscivicmc's Avatar
So other than buying the new rack I need the subframe out of a cx?
Old 04-17-2011, 04:48 PM
Technical Hero
HondaPartsHero's Avatar
lurker
Old 04-17-2011, 05:56 PM
confidence's Avatar
subframes are the same. you just need the rack and the U joint that connects the rack to the steering column. the EX spindle is bigger than the dx/cx one
Old 04-17-2011, 06:16 PM
uscivicmc's Avatar
aahh thanks man.
Old 04-18-2011, 05:07 AM
Seagull Management
94EG8's Avatar
Yes.
Subframe is different, U shaped clamp is smaller for a manual rack, you can use the larger clamp and shim it up with something but for not that much more effort you can just use the right subframe.
james_moore
02-22-2012 11:52 AM
TurboEK9Coupe
09-28-2008 04:29 PM
2DoorBandit
01-29-2006 09:57 PM
1337 Si
23
04-09-2004 12:25 PM
aeolus
05-11-2003 11:03 AM
Quick Reply: Cx steering rack into ex
