clunk
Old Apr 18, 2013 | 12:20 PM
hondaskerp2000's Avatar
Icon2 clunk
hey i have got a question for everyone, when starting off first thing in the morning in reverseing out and turning the wheel i get a very loud clunk coming from the front end then again when i go forward turning the wheel. i have replaced about everything there from the strut mounts, struts shocks tie rods control arms everything lets say and the clunk is still there. i have had it looked at by many shops and no one can figure it out because once you lift it in the air it NEVER makes that sound.......any ideas???????
Old Apr 18, 2013 | 12:39 PM
kcoen's Avatar
Default Re: clunk
Have you replaced your cv axles? One of them could be bad causing the clunk you are describing.
Old Apr 18, 2013 | 01:26 PM
TIMMY4TOES's Avatar
Default Re: clunk
x2
Old Apr 18, 2013 | 01:48 PM
grumblemarc's Avatar
The Grumpiest
Default Re: clunk
From the front end of what? have no clue what car you're talking about.
Old Apr 19, 2013 | 04:13 AM
Default Re: clunk
sorry its a 2000 honda civic ex. Yes i have replaced both cv axles twice cause i thought i got some bad ones and its hard to tell where up front it comes from
Old Apr 19, 2013 | 05:09 AM
hunan beef's Avatar
Default Re: clunk
When they put it the air did they check the front wheels for any play (side to side or top to bottom)?
Does it happen when you turn only right? Or only left?
Could be inner or outer tie rods (I saw you replaced those)
Lower ball joints
Front sway bar bushings or endlinks
Old Apr 19, 2013 | 08:51 AM
Default Re: clunk
i did the ball joints and swaybar end links and bushings, pretty much everything i think. when you lift it in the air it wont make a sound. and there is no play in the wheels themself everything as tight as a virgin lol
Old Apr 20, 2013 | 11:25 AM
Default Re: clunk
all i know is that it is driving me crazy i wish it did it when i lift the car be alot easier, i just didnt know if anyone has had the same issue but i reverse with the wheel turned to the left then clunk then go to go straighten it out and clunk. so its both turning left and right
PolkaSauce
Honda CR-V & Element
Apr 23, 2019 02:02 PM
93dabeast
Suspension & Brakes
Mar 14, 2007 09:44 AM
93dabeast
Mar 14, 2007 04:11 AM
amb4081
Jun 23, 2006 11:24 AM
servion
Jul 7, 2003 07:06 AM
