Finally Boosted...........
Finally finishing up my install , its been a interesting and very educating journey to say the least ! Heres a few pics please feel free to chime in.
And now how she sits patientially waiting for my fuel pump and injectors to arrive via ups.......then she's off hopefully friday to be tuned !!!!!
Lately been trying to fix small things such as those ugly zip ties on my radiator and the charge piping on the drivers side that looked like **** and needed to be cut and adjusted.
Well the fitting on the right i had laying around the house for a while with intentions on using it for my oil return until it suddenly hit me that aluminum cannot be welded to my steel oil pan so i took a trip down to AED in richmond and purchased the fitting on the left and i can say now after having to pull my oil pan twice and put my car back in the air 3 times this may have been my worst purchase of this whole adventure cause this thing leaked like hell everytime !!
Just a quick pic of my dumptube and the weird location of my o2 sensor bung..........I measured twice and my wideband cable should be long enuough !
And finally for a quick rundown of my setup..............
stock b18 approx 70k
stock b16 trans
new 6 puck unsprung clutch
57 trim turbo
cheap steel no name manifold
no name 2.5'' open downpipe
2.5'' charge piping
walbro 255 fuel pump
dsm blue top 450s
chipped p28 w/ neptune
7lb wastegate spring............
stock b16 trans
57 trim turbo
2.5'' charge piping
dsm blue top 450s
let me add that i just recently purchased the car about 2 months ago and since then ive been correcting several things on the car . Things such as the bungee cord around the battery and electrical tape over holes in the trunk were a hideous spoiler was placed. Dangling wires throught the engine bay and things or that sort so please dont mind the remaining eyesores as they will be tended to vey soon.
Idk about that manifold
But I'll hold my comments. Having a turbo is fun but you have to pay attention to everything about your car
Please speak up......I know that manifold will probably have cracks in it before the end of the year. But I'm all in for opinions and suggestions let me hear it !
Looks just like my 1st turbo setup 10 years ago. Not to be a downer but that manifold is going to crack. You can pick up a log style mani for pretty cheap nowadays. You're going to have a blast driving that thing.
Ok...
What type of turbo and wastegate are you running? My neighbor has that manifold, they're not great, crack central. Cast manifold would hold up better.
The turbo is a ebay 57 trim .....godspeed I believe is the brand if that matters......and I don't have a clue about the wastegate it was on the cast manifold I had that was the wrong flange for my turbo ao I ditched the cast manidold and kept the wastegate.
Psi is not a measurement of power. I can not comment on Godspeed turbos because I run a Garrett. If you have little information on the wastegate then you might want to investigate that before you move forward. If your going to turbo your vehicle I would hope you'd know everything there is about the items your installing.
yes i am fully aware of that and by no means at all was that a reference to a power goal just simply stating that with my supporting mods and the fact that im on a stock map sensor that 10lbs is what the car will be tuned to accordingly regardless of power levels achieved at the amount of boost.
Instead of re doing the entire setup, take that manifold and brace it like crazy. It will last longer and can give you time to save up for a new manifold and downpipe setup. People have made those manis work with a lot of bracing. Not sure how long though.... The inline pro manifold is real nice if you are looking into something cast.
yes i agree about the wastegate i was told that it was a off brand ebay wastegate with a 7lb spring in it. Not that that justifys it usage any but as far as info on the part that is currently where i stand.
