4 lug to 5 lug conversion
I just did the conversion last week, and assuming you already have rear disk brakes, it's fairly simple.
You will need:
rear v6 hub bearing assy, rear disks (may reuse calipers and pads)
front v6 hub, new bearings, v6 calipers, v6 discs and pads(bigger than 4cyl)
Dorman makes fairly priced hubs it's what i used.
do a search, there's a few DIY about it.
axles will fit without issues btw
You will need:
[QUOTE=Nathan007;48699281]I just did the conversion last week, and assuming you already have rear disk brakes, it's fairly simple.
You will need:
axles will fit without issues.
i know this thread is old but its worth a try can the same be done with a 99 accord lx 2.3l? Just switch hubs on front and change rear knuckles to a disk n 5 lug???
You will need:
Dcsports92
Feb 27, 2008 05:20 PM
WagOvan Man
Feb 28, 2006 02:00 PM
