Rear Susspension problem
Old Apr 16, 2013 | 08:56 AM
93Eg_SiR's Avatar
Default Rear Susspension problem
Currently driving a 93 Eg; Whenever I make a sharp right or just a hard right turn i get some nasty wheel rub from the back left tire, also happens when I hit a hard bump. I dont get any other tire rub except from that tire.
I just installed knoi yellows and skunk2 springs. everything is done right but that problem still occurs still only on the one tire.
I have no clue what could be causing this, any help would be appreciated
Old Apr 16, 2013 | 09:09 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Rear Susspension problem
Spring rates, tire & wheel setup and how low?
Old Apr 16, 2013 | 09:12 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Too low?
Old Apr 16, 2013 | 09:15 AM
ej7attack's Avatar
did you put new bushings on the top hats of the struts? did a similar job for a buddy, still had a noise in the rear right side.it sounded like tire rub. i rode in the back while he drove and found the bushing to be shot, even if it doesnt look like it. he had a 1.5 in drop
Old Apr 16, 2013 | 09:17 AM
azzazel_9's Avatar
Sounds like you need to adjust dampers or that side is lower than the rest?
Old Apr 16, 2013 | 05:54 PM
93Eg_SiR's Avatar
The Rub would happen before I Replaced the struts and springs, Used to have really old koni's and neuspeed springs.
Could it be something wrong with the Toe rod?
Old Apr 17, 2013 | 03:44 AM
The Grumpiest
I asked you a question that directly relates to the problem you're having. Care to answer it?
Old Apr 17, 2013 | 06:08 AM
93Eg_SiR's Avatar
Spring rate Front: 173 Lb-in/520
Rear: 106 lb-in/291
Tires: Kumho 205 55R-15
I don't think any of this is the problem because it only happens to rear left.
Old Apr 17, 2013 | 06:19 AM
PeRK82's Avatar
Rear: 106 lb-in/291
Check the Trailing arm bushing. They are easy to replace , if only one is shot i would replace both of them ( one one each side ).
If it is bad, it would change the ride height ever so slightly. Another culprit may be body work to the notorious fender wheel.
Old Apr 17, 2013 | 08:45 AM
The Grumpiest
I also asked you how low you were. Do we have a problem answering all questions? I asked you how low you were as well. Good luck figuring it out.
Old Apr 17, 2013 | 08:52 AM
azzazel_9's Avatar
Lmao @ marc. Measure your height at all fenders and make sure all heights are correct/match and as stated check trailing arm.
Old Apr 17, 2013 | 05:41 PM
BrakeExpert's Avatar
That guy sure is grumpy. How is your RTA bushing? If your car is lowered, and you didnt replace this with a new, clocked bushing, odds are its torn on the bottom. Check that first, then get back to checking the rest of the suspension.
Old Apr 18, 2013 | 10:33 AM
93Eg_SiR's Avatar
I Checked my RTA Bushing Yesterday and it looks like it could be torn. I plan on changing both sides out and seeing how that goes from there
Old Apr 18, 2013 | 11:41 AM
Emeraldbomber's Avatar
But how low are you??????
osix
Nov 21, 2015 10:43 AM
3rdgen3
Suspension & Brakes
Mar 16, 2009 03:18 PM
Intense3.2
Mar 3, 2005 11:23 AM
ViEtBoY9o9
Jan 2, 2003 12:38 PM
DevilSolSi
11
Dec 16, 2002 08:50 PM
