idle help!
Old Apr 15, 2013 | 10:47 AM
Redis_323's Avatar
Icon2 idle help!
hey all.
so i installed some used headers that i just purchased but now my car shakes and feels like its about to turn off WHEN i come and/or when im coming to a complete stop.rpm needle drops to anywhere from 0 mto 500 (yes below 1) when it starts to feel like that. when i turn the car on and i am stepped on the brakes it doesnt do it, its only after driving. car also rattles at times not really sure but i think its at higher rpms any ideas??
recently installed headers are "megan racing" brand
Headers taken off before are no brand looks like ebay brand
i own a ej1 and the car didnt do this with the ebay brand headers that were on previously.
thank you all in advance
Old Apr 15, 2013 | 10:58 AM
Redis_323's Avatar
Default Re: idle help!
also would the car turn off??
Old Apr 15, 2013 | 11:27 AM
PunchedGuava's Avatar
I've experienced something similar but with a different issue. I replaced the evap canister because of a leak and after the new (used) one was put in, my car seemed like it was going to stall at every stop. It stalled once when I came to a complete stop. Just once, but I kept on driving after that it sort of fixed it self.
For you, however, I'm not exactly sure...
Old Apr 15, 2013 | 11:31 AM
Redis_323's Avatar
really? how long ago was that? do you still drive that vehicle? hopefully mine just needs to adjust or something.
Old Apr 15, 2013 | 11:52 AM
buster97's Avatar
Don't quote me on this but it may be a leak in your abs system if it does it during any kind of breaking
Old Apr 15, 2013 | 12:00 PM
Redis_323's Avatar
that is a different issue i have that i want to address since ive noticed that at times when i brake sometimes i feel like the tires are about to fall off. unfortunately the issue im having here might be different since it just started today due to the fact that i just installed these other headers
Old Apr 15, 2013 | 12:33 PM
TIMMY4TOES's Avatar
is your o2 sensor hooked back up correctly?
Old Apr 15, 2013 | 12:40 PM
Redis_323's Avatar
the header i installed had its own so i didnt put mine in..... no cell code at all though
Old Apr 15, 2013 | 03:34 PM
Redis_323's Avatar
any more input anyone?
Old Apr 15, 2013 | 05:56 PM
Redis_323's Avatar
6:57
Old Apr 15, 2013 | 07:08 PM
crazyhouse2011's Avatar
I got me an EJ1 and last night the lighting would dim considerably if I stepped on the brake pedal while idling at a stop, then bring itself back up. also, the radio was having problems reading my USB drive, which it never does, so I figured theres a grounding issue and I should maybe remove my ground wires and clean them, and clean the grounding points for a better connection. Sometimes if you add extra grounds it can smooth out your electrical system.
dices543
Jul 24, 2010 09:16 PM
L_K
Sep 3, 2006 08:46 AM
SpoolnG2
Jan 12, 2003 06:36 PM
fenixl13
16
Feb 12, 2002 05:19 PM
