Car hesitates and loses throttle control
Old Apr 14, 2013 | 07:03 PM
Palamala112's Avatar
Default Car hesitates and loses throttle control
I just bought this car and it has a strange issue, if somebody knows anything that could help please share.
1997 ek hatchback with a 99 gsr engine obd2 p72 ecu
Issue: very boggy and hesitant around 2-3k rpms
Replaced map sensor, fuel filter, and tps sensor, checked voltages to the 3 tps wires. Replaced spark plugs, distributor cap, wires.
-only CEL codes for evap emissions
-losing coolant, possibly burning. about 0.5-1.0L every 350k ish. weird thing is I pressure tested it about 2 weeks ago and the cooling system held the pressure.
Old Apr 14, 2013 | 11:06 PM
9psiTURBOsi's Avatar
Default Re: Car hesitates and loses throttle control
Could it be misfire?
Old Apr 15, 2013 | 03:14 AM
GMAN64's Avatar
Possible throttle position sensor problem. It might have a dead spot in it and it usually won't trip a check engine light.
Old Apr 15, 2013 | 06:12 AM
info in first post.
Old Apr 15, 2013 | 09:45 AM
GMAN64's Avatar
Not sure on the specifics (not familiar with Honda systems just yet). But you should be able to sheck the resistance values of the TPS at the terminals while it's still on the vehicle. As you operate the throttle the resistance should increase and or decrease (not sure which) from just off idle to the open throttle position and vice versa. If the ohmeter shows a discrepancy when the throttle position is where your problem occurs I'd say that's your culprit. A dead spot on the scrub board makes the computer think that the engine is just idling even though you're on the gas. Part should cost @ $50 - $60 aftermarket.
Old Apr 15, 2013 | 04:26 PM
hybridmiklo's Avatar
hold on there. before you jump the gun what exact code was it? purge control? if the purge valve stays open you can have that same exact problem
Old Apr 15, 2013 | 04:46 PM
GMAN64's Avatar
Good call "hybridmiklo" !!!!
updated first post.
Old Apr 17, 2013 | 07:04 AM
Kwackerjack's Avatar
May be a long shot but :
A friend of mine has a 1999 Honda Accord Type R, Under the nearside dash if you pull back the carpet there is a cluster of wires for the ECU.
They were re-wired badly and every time someone sat in the passenger seat or he hit a bump it caused the car to lose power and act weird.
He spent €400 replacing sensors only to spend a few € on wire connectors and the car now has no issues
Old Apr 17, 2013 | 10:54 AM
updated first post.
Old Apr 21, 2013 | 12:26 PM
updated first post.
Old Apr 23, 2013 | 09:39 AM
bump
Old Apr 30, 2013 | 01:04 PM
skylerreniger's Avatar
had the same problem with my car and it was a crack in the head. eventually i started burning more and more coolant and the car started running way worse and was bogging more as the crack got bigger.
si del sol 94
18
Sep 16, 2009 07:39 PM
Jakester9500
Nov 19, 2008 07:10 AM
envee
10
Sep 18, 2007 05:58 PM
funk2244
Apr 13, 2006 12:28 PM
