Coilover question
Old Apr 14, 2013 | 02:43 PM
PunchedGuava's Avatar
Icon2 Coilover question
Hello. I've recently had some function and form type 1's installed on my 2000 ex. A couple days later I wanted to adjust the rear height so when I jacked up the rear, I noticed something very strange. From where the coilover connects to the real control arm,on the rear side, the screw looked as if it's missing a nut... Is that normal? Do these coilovers have some kinda built in nut, tread kinda thing going on? I tried to loosen the screw to check but it's in there pretty tight and I don't have a air gun to loosen it.
Here's a pic:
http://www.4gp.tw/b013/1365979329123.jpg
Old Apr 14, 2013 | 02:48 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Coilover question
How would you not know if you installed them? Did you not compare them to the other side?
Old Apr 14, 2013 | 02:58 PM
Sorry, I will rephrase that. I had a friend of a friend do them. I apologize for the confusion and will edit the OP
Old Apr 14, 2013 | 02:59 PM
The Grumpiest
The nut looks threaded. To confirm all you have to do is look at the other side of the car.
Old Apr 14, 2013 | 03:06 PM
Both sides look the same. Or, do you mean the front of the arm where the screw enters or the rear side of the arm.. Which I've posted a picture of?
Old Apr 14, 2013 | 03:19 PM
98civdx's Avatar
Master Detailer
It's not missing anything. Although it doesn't look like a nut, it is.
Old Apr 14, 2013 | 03:28 PM
Thank you guys, peace of mind achieved for the time
Being... On to fix my exhaust rattling against the heat shield...
Old Apr 14, 2013 | 03:42 PM
azzazel_9's Avatar
Yea that hole there is threaded i suppose if you wanted to put your mind at ease you could put a nut on there but it isn't needed
crxtuner0
Suspension & Brakes
Feb 3, 2009 07:55 AM
pearl
Suspension & Brakes
17
Sep 30, 2007 02:18 PM
dynamitespy
Suspension & Brakes
Jun 16, 2006 08:14 PM
civic-si-2000
11
Oct 5, 2003 09:13 PM
SD_EM1
Jul 16, 2003 04:56 PM
