93 Del Sol SI D16Z6 - 2nd Cylinder Low Compression - What Next?
Old Apr 13, 2013 | 05:05 PM
Robert Stern's Avatar
Default 93 Del Sol SI D16Z6 - 2nd Cylinder Low Compression - What Next?
Hi All,
I have done a compression test and found that my cylinder number 2 is about 50-60% less compression than all the rest, dry and wet.
Just wanted to get some advice as to what I should do next to see if this thing is worth fixing, or to just dump it and get a replacement motor, seeing as they are only around $900-1000, I don't think it makes sense to spend a lot trying to fix this one.
2nd, if I continue to drive this one with low compression, whats the worse that could happen? It runs pretty good considering, a little rough idle, but still has power.
Old Apr 13, 2013 | 05:31 PM
Lizardslap's Avatar
Default Re: 93 Del Sol SI D16Z6 - 2nd Cylinder Low Compression - What Next?
what motor is it and do a leak down test could be something like a burned valve or somthing
Old Apr 13, 2013 | 05:45 PM
B_Swapped93's Avatar
post the numbers wet and dry
Old Apr 13, 2013 | 06:49 PM
D16Z6 Motor
1st 2nd 3rd 4th
Dry 185 100 200 200
Wet 245 160 250 245
Old Apr 13, 2013 | 06:59 PM
That's a fare jump from dry to wet. i'd say rings starting to go mine only jumps 3-4psi max when i do a wet test. but that's not to say a leakdown test isn't a good idea.
Old Apr 13, 2013 | 10:21 PM
So, sounds like leakdown test is the way to go. that will at least point me in the right direction.
Old Apr 16, 2013 | 04:49 PM
So, took it to my local shop and for $25 they ran a leak down test.
Came back with 80% Leakage through the exhaust valve. Guy there said car shows signs of possibly having a turbo install previously and too be careful that fixing the exhaust valve might not solve all the issues, wouldn't know until its all opened up.
06BlackSi #45
Honda Civic (2006 - 2015)
Nov 22, 2009 06:55 AM
Skadaloz
Apr 8, 2008 10:02 AM
xvietxkhmerxboix
Mar 3, 2006 03:05 PM
ondahush
Jan 5, 2006 11:47 PM
PA MATT
Jul 15, 2004 06:42 AM
