00 Civic 2dr EX: Orange connectors under passenger seats.Also annoying "beep".
Old Apr 13, 2013 | 07:59 AM
col1n's Avatar
Default 00 Civic 2dr EX: Orange connectors under passenger seats.Also annoying "beep".
Hello! I've been disassembling interior of my car and found these two orange connectors carefully mounted onto the floor!
Each of them has double wire, which go to the wire harnesses on both sides.
First i thought, that those are additional speakers wires to passenger seats, so i connected the twitter from the door (connectors fited perfectly with a click).
Then i thought, that those wires are disconnected from the music player.
So i opened Service manual to see what those wires are for... could'nt find them on the schemes!
What are those, fellas?
Thank you!
Also,how to get rid of that annoying beep, when both doors are opened without losing the light?
Cause i've found, that the light doesn't light up when drivers door is opened.
And here is the problem: previous owner disconnected door switch by unpluging the wire from it's place.I put it back and here comes the "beep"!
Thank you!
Old May 13, 2013 | 02:42 AM
col1n's Avatar
Default Re: 00 Civic 2dr EX: Orange connectors under passenger seats.Also annoying "beep".
I figured it out!
Those are connectors for rear ABS sensors!
Old May 13, 2013 | 12:30 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Door open should only cause a beep when lights are on and/or the key is in the ignition. Yours beeps all the time?
Old May 13, 2013 | 12:39 PM
thinhthan's Avatar
the door will beep when you open the door and the key is in the ignition and will have a tone if the lights are on and you open the door. in order to get rid of the beep when open the door and key in the ignition you gonna have to desolder the little beep thing off the module off the back of the fuse box
corpsebesideme
Jul 2, 2014 08:07 PM
curtie94
Mar 18, 2011 07:07 PM
93_teg_CT
Mar 30, 2006 12:54 PM
civicmark
Audio / Security / Video
Jan 2, 2003 11:31 AM
integra-modder
Sep 23, 2002 09:17 AM
