H23a Bluetop question
Old Apr 11, 2013 | 03:34 PM
1997PreludeH23A's Avatar
Default H23a Bluetop question
Hi. I have an H23a "Bluetop" motor in my 1997 Prelude SH and I was wondering if the H22a bolt ons from the 5th gen SH will fit on the H23 motor? Like if I get H22 headers will the ports line up to the H23? I've read that the H23a Bluetop is an H23 block with an H22 head but I just want to make sure before I buy anything.
Old Apr 11, 2013 | 03:42 PM
Sparksman's Avatar
Default Re: H23a Bluetop question
No, the SH bottom-end has completely different bolt on patterns then the base model H's. You can swap head parts all day. But you have to buy H series base model parts for the H23a bottom-end.
Old Apr 11, 2013 | 03:44 PM
Sparksman's Avatar
Look and see if your H23a has a P13 or PDE head. If it has the P13, look at your old engine, if it is 00'-01' should have one. The PDE is a better head, some H23a blut-tops came with PDE's.
Old Apr 11, 2013 | 04:01 PM
How would I tell between P13 and PDE?
Old Apr 11, 2013 | 04:05 PM
Sparksman's Avatar
It should be stamped on the side of the head itself. Not a sticker, but its in the actual aluminum casting. You should be able to see the casting code "p13 or pde" and the year of production.
Old Apr 11, 2013 | 04:54 PM
I'm guessing it's a P13. I was that on my distributor.
Old Apr 11, 2013 | 05:03 PM
Sparksman's Avatar
It should be stamped above the middle right exhaust port on your head. Directly above your header, on cyl 4 i believe "1-3-4-2". There should be other stamps and circle markings. The head stamp is on the right half of the head if you looking at it as if it was still in the car. I dont know any other way of describing it to you lol.... Same location on all H series heads.
Old Apr 11, 2013 | 05:09 PM
Yeah I figured it would be there. I'll have to check that tomorrow cause I have a plate over my header and I'm not planning on taking it off tonight.
Old Apr 11, 2013 | 05:32 PM
Sparksman's Avatar
Is it the original heat shield your talking about? Because if that is what your talking about, you should still be able to see it. My whole point was if you had the better head why not use it.
Old Apr 11, 2013 | 06:25 PM
Yeah It's the original one. I'll have to check tomorrow cause it's way too dark and cold. Hopefully I have the better head.
not-a-stang
Feb 5, 2008 01:41 PM
bshshondaman06
Dec 28, 2005 02:16 PM
schreck5413
Sep 12, 2005 06:11 PM
JDMnatic
Feb 9, 2005 05:06 AM
DLB1994
Sep 23, 2001 05:07 PM
